Newbie - 79 MB 300 CD - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 09-18-2006, 09:00 AM Thread Starter
Date registered: Sep 2006
Hello All,
I recently purchased 79 300 CD - it runs great and very comfortable - after the 1st week of driving the - what looks new - battery died. I had the alternator tested and they determined it had to be replaced - that was done a week ago. Car started fine all week - then on SUN the battery was dead again. Any suggestion on what to check next?
Perplexed in Santa Fe, NM
Thanks...
gill-tapia is offline
post #2 of 8 (permalink) Old 09-18-2006, 10:05 AM
Date registered: Jun 2006
Vehicle: 1981 300CD, 1973 280C
Something is remaining on. Maybe the rear dome light? it has a seperate switch on the dash. glow plug relay stuck? It needs to be tested for a battery draw. Its a simple test. Any good auto electric shop can do it.
carnut1 is offline
post #3 of 8 (permalink) Old 09-18-2006, 11:23 AM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 712 Post(s)
A bad ACC Servo can suck the life out of a battery in a few days time.
GeeS is offline
post #4 of 8 (permalink) Old 09-18-2006, 11:57 AM Thread Starter
Thank you for the info... But may I ask what the ACC Servo does?
Grateful,
.a.
post #5 of 8 (permalink) Old 09-18-2006, 12:29 PM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 712 Post(s)
It's a black plastic thing about half the size of a football. Lots of vacuum connections and four water hoses -- it's your car's version of a heater control valve.
GeeS is offline
post #6 of 8 (permalink) Old 09-19-2006, 04:31 AM
cool92092's Avatar
Vehicle: 1972 Mercedes-Benz 280 SE
Did you simply try cleaning the connectors on the battery and removing rust/acid. This worked for my car. Check the voltage at the battery with all electrical on. Should still be around 14V. If it is less, the battery will discharge over time. Also check the acid in the battery, make sure there is enough. good luck.
cool92092 is offline
post #7 of 8 (permalink) Old 09-19-2006, 08:03 AM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 712 Post(s)
I'm sure that was all done when took the car in and had his alternator swapped out...
GeeS is offline
post #8 of 8 (permalink) Old 09-24-2006, 09:52 AM
Vehicle: Many MBs
I concur with GermanStar. You appear to have a key off current drain and it is most likely the servo. You can run a current drain test by dicsonnecting the negative terminal and connecting a one ohm ten watt resistor between the post and terminal. Check the voltage drop across the resistor with a DVOM. You should not exceed .05 volts. You can start removing consummers starting eith the servo until the meter drops below .05 volts. Good luck.
autozen is offline
    Which diesel model is better? 240 or 300 or 300 turbo? eso7 W123 E,CE,D,CD,TD,TE Class 22 05-17-2010 07:15 PM
    GE 300 & E 300 engine difference - or Brabus 3.6 911fanatic G-Class 8 02-23-2005 02:43 PM
    newbie workin on a 300 with diff question misterfixit G-Class 16 02-07-2005 12:56 PM
    300 TE 3.6 4matic Brabus and 300 TE sportline. Mark H. W124 E,CE,D,TD Class 4 09-17-2003 02:41 AM
    Newbie needs help with 77 300 Guest (MBNZ) W124 E,CE,D,TD Class 0 12-26-2000 06:10 PM
