Limited Slip or Not? How to tell? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-16-2006, 03:26 PM Thread Starter
Date registered: Sep 2006
I'm working on my dad's 1974 240d (w115), 4 speed manual. According to the service manual, I'll need a different oil for the rear axle differential depending on whether it's limited slip. I don't like the idea of finding out by dumping the clutch so hard that I can spin the wheels with a little 4 cyl diesel. Is there a number or other ID on in the casting of the diff. case? Maybe it simply was standard or not available on this exact year/model/engine combination? Thanks.
FieroGT42 is offline
post #2 of 5 (permalink) Old 09-16-2006, 03:39 PM
Date registered: Jun 2006
Vehicle: 1981 300CD, 1973 280C
Most limited slip rear ends have a tag on the fill plug. If not, then usually with both rear tires off the ground, rotating one by hand, you should see the opposite wheel rotate the same direction if it has limited slip. If it rotates the other direction it is not. The gear oil if I'm not mistaken is the same. You add an additive to the conventional oil to lubricate the clutches in a limited slip. I really doubt if it has limited slip.
carnut1 is offline
post #3 of 5 (permalink) Old 09-16-2006, 08:11 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
I've never even heard of limited slip on a w115. I wouldn't give it a second thought...
GeeS is offline
post #4 of 5 (permalink) Old 09-24-2006, 10:52 AM
Vehicle: Many MBs
I doubt if any 115 had limited slip, but if it does there will be a large flat metal tag on the back of the housing stating that.
autozen is offline
post #5 of 5 (permalink) Old 09-24-2006, 02:35 PM
Date registered: Jun 2004
Quoted: 5 Post(s)
If it has ,you CANNOT use ordinary Hipoid oil in the diff.
Check the cars option plate ( in front of the radiator,it's a small oblong plate with numbers stamped into it) .Generally it will be stamped as "211" or "256",
If those numbers appear on the plate then you a W115 with LSD,not uncommon in Europe where the snow and ice made it neccesary for taxis to have this option. As your car is a US car ,the number will appear because it would have to have been ordered especially with it.( IF it does indeed have the LSD)
Buy the special oil from a Mercedes parts dealer,no one else has it.
mercmad6.3 is offline
    Limited Slip Differential ErikFinn R129 SL-Class 13 03-13-2007 05:30 AM
    Limited Slip Differential Mark420 W126 S,SE,SEC,SEL,SD,SDL Class 13 02-27-2005 11:51 AM
    Limited Slip Diff - Help! ScrapingScrap W126 S,SE,SEC,SEL,SD,SDL Class 1 01-27-2005 12:19 PM
    Limited Slip? MacDubois W126 S,SE,SEC,SEL,SD,SDL Class 0 11-23-2003 11:25 AM
    limited slip differential Guest (MBNZ) W124 E,CE,D,TD Class 3 03-11-2002 07:50 AM
