stalling 4.5 280 se 1972 - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 09-16-2006, 12:40 PM Thread Starter
Date registered: Sep 2006
car starts fine then stalls after warm up. cant get it to restart. turns over fine but wont fire. anybody have any ideas. 72 280 se 4.5
tukey is offline
post #2 of 6 (permalink) Old 09-16-2006, 04:27 PM
cool92092's Avatar
Vehicle: 1972 Mercedes-Benz 280 SE
diesel or gas?
cool92092 is offline
post #3 of 6 (permalink) Old 09-16-2006, 04:31 PM
cool92092's Avatar
Should be gas........(from other post)
This may not be the case however it is worth checking your alternator. If the voltage applied to the sparkplugs is too low (as was in my case) the engine would sputter and symptoms similar to yours. When I went to check the enginge, found a small wire with insulation breakdown. Fixed it and works much better. Could also be the case if your alternator is bad or have too much electronics loaded in there. Worth a try to have a look if anything.
post #4 of 6 (permalink) Old 09-17-2006, 06:26 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
Does it restart without issues after it cools down? How's the fuel pump and filter? And do you have spark from the coil?
Grubeguy is offline
post #5 of 6 (permalink) Old 09-17-2006, 08:51 PM Thread Starter
it does start after cool down. dont know the answer to your other questions?
haven't driven much this summer, no time or money
by the way I used to work at the lighthouse hostel in monterey bay.
tukey is offline
post #6 of 6 (permalink) Old 09-24-2006, 11:36 AM
Vehicle: Many MBs
First you need to determine if it's fuel or fire. You can determine that by checking spark on the coil wire. If good spark, you can tee in to the fuel ring with a pressure gauge to see what is happening there or remove a bank of injectors, ground the coil wire and crank the engine. The injectors should fir sequentially.
autozen is offline
    heater blower 1972 280 sel 4.5 juan74 Vintage Mercedes-Benz 17 07-05-2010 04:35 PM
    1972 280 SEL For Sale dwjohnsonkb For Sale/Wanted/Trade/Giveaway 0 01-02-2006 07:55 AM
    1972 280 SEL For Sale dwjohnsonkb For Sale/Wanted/Trade/Giveaway 0 01-02-2006 07:50 AM
    F.S. 1972 280 SEL 4.5L willis5275 For Sale/Wanted/Trade/Giveaway 2 06-12-2005 04:58 PM
    1972 280 se Guest (MBNZ) General Mercedes-Benz 1 05-15-2001 04:04 AM
