Fuel not consistently flowing after sitting TOO long- 1972 280 SE - Page 2 - Mercedes-Benz Forum
post #11 of 16 (permalink) Old 09-07-2006, 07:56 AM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 735 Post(s)
If the car is a 6-cylinder, it's the same. It's a V8, it's different.
GeeS is offline
post #12 of 16 (permalink) Old 09-08-2006, 04:12 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 103 Post(s)
When you first turn the key over (but without cranking the engine), you should hear the pump run for about a second or so. When I bought my 108, I had similar issues, so I replaced the fuel filter and pump, and ran all the gas out of the system before putting more in. I'm thinking that if you had the pump "unstuck," then it's got some issues still. The pumps can run on the pricey side, but I've seen them about $250 on eBay ...
Replacing the pump and filter is pretty easy and quick too.
Grubeguy is offline
post #13 of 16 (permalink) Old 09-08-2006, 04:27 PM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 735 Post(s)
Originally Posted by Grubeguy
.......but I've seen them about $250 on eBay ...
New or reman? Either way, the 6-cylinder pump costs more than yours...
GeeS is offline
post #14 of 16 (permalink) Old 10-04-2006, 12:36 PM Thread Starter
Date registered: Sep 2006
The fuel pump is ok, or at least does pump fuel before it turns off from pressure (I think). The filter in the tank looked like a candied apple, so it was replaced. I've replaced the fuel filter, the entire hose up to the fuel damper, and replaced the fuel regulator, and all of the hoses on the rails. Fuel does flow through the damper, but does not get through the new Bosche regulator. They used white paint on the adjustment nut, so I didn't want to mess it up. Can the damper cause a problem? Do I need to get an in-line fuel pressure gauge and measure the pressures? What should they be at the fuel damper? What should they be if I adjust the regulator?
Floydf is offline
post #15 of 16 (permalink) Old 10-04-2006, 03:14 PM
Boring Cars...meh!
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: 81 280E, 84 500SEC, 87 560, 89 "300E", 91 500SL, 15 E350 4Matic Estate, 71 BMW 2002, +others
Quoted: 18 Post(s)
Fuel pressure 28-32 psi at the regulator. If you need more specs;
http://www.benzworld.org/forums/w116...eshooting.html
Nutz 4 Benz is offline
post #16 of 16 (permalink) Old 10-04-2006, 07:18 PM Thread Starter
Thank you for that link. I did a forum search and found that link this afternoon and printed it. I think I will have to go buy a pressure gauge. I just verified again that the fuel pump has no problem pumping fuel when the fuel line is disconnected before the damper. Then, I hooked the fuel line directly to the regulator, but no fuel came out (with the output hoses disconnected). It seems like it builds quite a bit of pressure, because fuel sprays out when I unhook a hose, but I'm not sure right now exactly how much. And, I'm not sure what the new regulator is set at. I do know that it is frustrating!
Floydf is offline
    1972 Mercedes 114 280 CE Coupe QX19 Vintage Mercedes-Benz 12 11-25-2007 01:27 PM
    1972 280 SEL For Sale dwjohnsonkb For Sale/Wanted/Trade/Giveaway 0 01-02-2006 06:55 AM
    1972 280 SEL For Sale dwjohnsonkb For Sale/Wanted/Trade/Giveaway 0 01-02-2006 06:50 AM
    F.S. 1972 280 SEL 4.5L willis5275 For Sale/Wanted/Trade/Giveaway 2 06-12-2005 03:58 PM
    1972 280 se Guest (MBNZ) General Mercedes-Benz 1 05-15-2001 03:04 AM
