common problems I've noticed in 280se's - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 08-21-2006, 09:57 PM Thread Starter
Date registered: Aug 2006
When I was out test driving and fiddling with these cars before I bought mine, I noticed a few broken things that seemed common on them, so I compiled this list. Maybe we can put our heads together for some common solutions.
-The automatic column shift handle was usually loose and wobbly. In one instance, the car wouldn't even go into park...
-The shift indicator wasn't working (it was just stuck in park when you moved the shifter).
-Broken heater controls.
-Odometer (a classic benz problem, it seems).
As far as the odometer, I know that if you remove the unit and pull out the rod (carefully) that that little number wheels sit on, you can scuff up the surface so that they start spinning again.
The heater controls were made out of bad 60s bakalite or something. And replacements are about $130 bucks. I'd almost rather just machine aluminum ones as they'd last a hell of a lot longer.
Anyone have comment on the wobbly shifting? I think it has something to do with desintegrating plastic...
Any other common problems/solutions you folks noticed on these cars?
borisshiner is offline
    Common Problems (I Searched!) TangoRed W210 E-Class 23 05-22-2015 07:44 AM
    Common problems on G500s BENZITEAM G-Class 10 03-09-2006 03:43 PM
    common problems benzpimp W202 C-Class 0 01-03-2006 11:20 AM
    Common problems? john88zxt W124 E,CE,D,TD Class 2 12-17-2003 01:20 PM
    Common W126 Problems [H] Spetsnaz Op W126 S,SE,SEC,SEL,SD,SDL Class 3 04-14-2003 04:08 PM
