Fuel injection adjustment & transmission shift points - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 08-16-2006, 08:00 AM Thread Starter
Date registered: Jul 2006
Vehicle: 1973 280SE 4.5
Hello again ---
I have two questions for all of you. First, when rotating the knob on the "brain" which controls the gas/air mixture in a 1973 4.5L engine, which way (clockwise or counter-clockwise) is rich and which is lean? Second, is there any adjustment which can adjust the shift points in the automatic transmission in this model (280SE 4.5)? The one I have wants to upshift too early, resulting in what feels like "lugging" all the time.
Thanks for the advice,
fatshot is offline
post #2 of 4 (permalink) Old 08-16-2006, 10:17 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 95 Post(s)
The tranny shift points are internal to the tranny, if memory serves. I had mine rebuilt 6 months back and had to have it adjusted (shifted very sloppily) at the shop.
Grubeguy is offline
post #3 of 4 (permalink) Old 08-17-2006, 12:51 PM
Peoria Benz's Avatar
I believe that clockwise is rich. But remember that only effects the mix at idle. You can effect the tranny shift habits with the control rod that comes from the throttle linkage. I have seen these disconnected and the car drives like its all screwed up. Good luck!
Peoria Benz is offline
post #4 of 4 (permalink) Old 08-19-2006, 06:37 PM
Date registered: Jun 2006
Vehicle: 1981 300CD, 1973 280C
Make sure the control rod going down to the trans has good bushings and it is secure at the trans lever. Mine were missing and it upshifted early and I had no passing gear.
carnut1 is offline
    1973 4.5 fuel injection adjustment fatshot Vintage Mercedes-Benz 3 08-01-2006 11:55 AM
    Diesel shift points 1982_300SD W123 E,CE,D,CD,TD,TE Class 1 07-11-2005 06:35 PM
    Transmission shift points 82gwagen R/C107 SL/SLC Class 1 06-29-2004 07:30 AM
    Transmission shift points......... C-Rod W163 M-Class 7 07-31-2003 07:38 PM
    How to remove the shift knob (manual transmission & pre-facelift SLK) Jordan (ITALY) R170 SLK-Class 2 10-29-2002 01:48 PM
