sunroof seal for 1976 280 - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 08-03-2006, 10:48 AM Thread Starter
Date registered: Jan 2006
Does anyone know where you can get a sunroof seal for a 1976 280 (114.060)
The seal on the car is a one piece tha cover both sides and front. The only seals I have found are a 3 piece set up with a rubber piece for the front and a metal/felt piece for each side, which won't work because there are no slots to insert the seals into. The original is glued to the body. Any info would be appreciated.
mbzplus is offline
    replacing sunroof seal idahodiesel W123 E,CE,D,CD,TD,TE Class 14 05-12-2014 10:20 AM
    1976 mercedes 280 - climate control problem sak01 Vintage Mercedes-Benz 4 10-03-2009 05:36 AM
    Sunroof seal replacement guzzimaster W126 S,SE,SEC,SEL,SD,SDL Class 1 04-29-2006 03:11 AM
    Sunroof seal Leeyore W123 E,CE,D,CD,TD,TE Class 6 01-09-2006 02:09 AM
    Fuse location for windows of 1976 Mercedes 280 MatterLaw W123 E,CE,D,CD,TD,TE Class 1 08-28-2002 12:00 AM
