107 Battery ground cable corrosion - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 08-03-2006, 10:04 AM Thread Starter
Date registered: Jul 2006
Fellow Benzers,
Just thought I'd pass along a recently discovered problem/solution with my electrical system. I experienced erratic operations in the headlights, electric windows, ignition and anything electrical, including instruments, which was caused by a corroded battery cable, where it attaches to the chassis, at the battery tray. I had cleaned the battery's terminal posts and cable ends, charged the battery and tested the condition of the fuses, all to no avail. The lights would dim, the windows operated up and down in a lethargic manner, and so on. The latest was that the car would not start when the key was turned to engage the starter. No clicks, growls or chatter from any of the relays/solenoids. It was total electrical disconnect. Testing the battery at the terminal posts showed the battery to be in a fully charged state. So, in conclusion, if you are experienceing any of these types of symptoms with your car, don't forget to check the battery cables, not only at the battery posts, but also to their respective terminations, AND, the attaching hardware, which should be replaced if any sign of corrosion is present.
Cheers,
Norman C
nortonfan is offline
    Battery cable questions Loi R170 SLK-Class 3 05-18-2006 06:17 PM
    AMG 107 Ground Effects Gunnz33 For Sale/Wanted/Trade/Giveaway 2 03-02-2006 08:44 PM
    AMG 107 Ground Effects Gunnz33 General Mercedes-Benz 1 02-27-2006 07:34 AM
    Alternator/Starter/Battery cable issue Gvigorus W123 E,CE,D,CD,TD,TE Class 26 11-10-2005 01:21 AM
    Amp Cable to battery ggbenz230 W203 C-Class 0 09-16-2003 06:12 PM
