1973 4.5 fuel injection adjustment - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 08-01-2006, 08:57 AM Thread Starter
Date registered: Jul 2006
Vehicle: 1973 280SE 4.5
My newly-acquired 1973 280 SE 4.5 will not pass Washoe County, NV smog tests. The hydrocarbon emissions are well within limits, but the CO is over limit on both the idle and the 2500 rpm tests (idle 4.23, limit 3.50; 2500 rpm 5.27, limit 3.50). The car came from Palm Desert, CA, which is at sea level, and Reno, where it is now is at 4500 ft. elevation. The car is obviously running too rich, but I don't know how to adjust the fuel injection. Can any of you out there give me any advice on how to do this?
Thanks in advance,
Dave
fatshot is offline
post #2 of 4 (permalink) Old 08-01-2006, 09:16 AM
Boring Cars...meh!
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: 81 280E, 84 500SEC, 87 560, 89 "300E", 91 500SL, 15 E350 4Matic Estate, 71 BMW 2002, +others
Quoted: 17 Post(s)
To adjust the CO you will need to access the ECU and turn the thumbscrew (detent potentiometer)on the side.Without a CO probe in the tail pipe,this will be difficult to get exact but the CO% should be 0.5 to 2.0 .Do adjustment only when the engine is fully warmed up!
Are you sure you don't have leaking injectors or vacuum leaks?
Also the pressure sensor contains an altitude compensating aneroid in it that adjusts automatically for changes in altitude.
http://i30.photobucket.com/albums/c328/nutz4benz/W123/6C3A9CA5-EDFF-4834-8125-34B70B20A676_zpsiyesrawz.jpg
Nutz 4 Benz is offline
post #3 of 4 (permalink) Old 08-01-2006, 10:26 AM Thread Starter
I would think that if I had leaking injectors, that the hydrocarbon levels in the exhaust would be elevated as well, due to unburned fuel in the exhaust. I could be wrong about that, but it makes sense to me. As far as vacuum leaks, I don't think I have any --- all the important vacuum hoses and clamps seem OK, and the entire peripheral vacuum system (door locks, trunk lock, gas cap lock) functions perfectly. I don't know for sure about the vacuum advance to the distributor, but it seems fine as far as looking at it and feeling it. I hate to fool with the ECU myself, as I really don't have a lot of specialized tools for Mercedes, although I used to be a decent mechanic in my younger days when cars were simpler. Thanks for the input.
fatshot is offline
post #4 of 4 (permalink) Old 08-01-2006, 12:55 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
My 108 wouldn't pass Colorado emmissions (it passed California's just fine though, 6 months later), so I took it for a high speed run on a long straightaway, in 2nd gear, and immediately re-did the test. I passed (though barely) with a pretty hot engine.
Grubeguy is offline
    FS: Bench Fuel Injector Tester and Fuel Injection System Pressure Tester JRBrown For Sale/Wanted/Trade/Giveaway 1 02-20-2006 09:50 AM
    Fuel Injection Tools for Sale (Injection System Pressure tester and Bosch Injector Bench Tester. JRBrown G-Class 1 02-20-2006 09:50 AM
    metal fuel line CIS fuel injection 79 280se w116 rfitts46 W116 S, SE, SEL, SD Class 0 01-28-2006 03:37 PM
    Fuel Injection gary1378 W163 M-Class 1 03-11-2004 10:08 AM
    Fuel Injection Guest (MBNZ) W201 190-Class 0 10-07-2000 07:53 AM
