Rear Door stuck & locked 1973 280sel 4.5 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-21-2006, 05:18 PM Thread Starter
ldshull's Avatar
Date registered: Jan 2006
Vehicle: 1973 280sel 4.5
Send a message via Skype™ to ldshull
Question Rear Door stuck & locked 1973 280sel 4.5
I can't get the rear door on the driver's side open. The door lock is about half way up and won't pull up or down. When trying to open from the outside, the button pushes in but it is really loose (no resistance). Same when pulling on the inside latch. Some more information on the status of the vacuum system: The other doors are fine though the vacuum system works partially on the passenger side meaning, when I lock the door they will not lock, when I unlock the door they will unlock. Any thoughts?
ldshull is offline
post #2 of 3 (permalink) Old 07-21-2006, 10:37 PM
Grubeguy's Avatar
Quoted: 99 Post(s)
Bad vacuum actuators perhaps? If you can manage to take off the door skins (I imagine it would be tricky with the door closed), you would see the vacuum actuator on the lower part of the door - a round object with a long rod sticking out of it, which in turn connects to the door lock. It's easy to disconnect (again, with the door open and all parts easy to get to).
Grubeguy is offline
post #3 of 3 (permalink) Old 07-22-2006, 09:52 AM Thread Starter
ldshull's Avatar
I'll give it a shot and post the result. Thanks!!
ldshull is offline
    plugs and wires 280sel 4.5 1973 ldshull Vintage Mercedes-Benz 7 06-14-2006 04:57 PM
    turning signals not working - 1973 280sel 4.5 ldshull Vintage Mercedes-Benz 7 02-04-2006 12:44 AM
    Is this 280sel a 1972 or 1973? ldshull Vintage Mercedes-Benz 8 01-29-2006 08:18 PM
    Buying 1973 280SEL 4.5 -Anything to watch for? ldshull W116 S, SE, SEL, SD Class 6 01-13-2006 12:20 PM
    steering wheel locked, key won't turn..84 300d.stuck in towaway zone..HELP please. turbosing777 W123 E,CE,D,CD,TD,TE Class 27 12-09-2004 10:33 PM
