61 W111 Coupe Low Compression Eng - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 07-16-2006, 08:37 AM Thread Starter
alydon's Avatar
Date registered: Mar 2004
Vehicle: 84 500SEL AMG, 90 560SEC AMG, 85 500SEC AMG Widebody
Quoted: 45 Post(s)
I just got my "Birth Certificate" from MB for my 1961 220SEb W111 Coupe. 42,000 original miles (actually 69,000 km's). A couple of interesting items noted in the original build spec:
Low compression engine 7.2:1
Suspension modified for poor roads
50 liter fuel tank
Car was originally ordered and sold in Argentina, them made it's way to Southern California in mid 60's. Car was fully resotred in mid 80's, except for the drivetrain, which has never been touched.
Does anyone know what Germany did to engines to lower the compression - is it just a matter of head deck height?
Since the car was in Argentina in the early 60's, I can understand the special ordering due to poor fuel quality and poor road paving.
Al
ID:	91991   Click image for larger version
alydon is offline
post #2 of 5 (permalink) Old 07-16-2006, 06:05 PM
benzmizer's Avatar
Vehicle: 1983 240d AT; 1993 e320 AT
Quoted: 4 Post(s)
N-i-c-e!!!
benzmizer is offline
post #3 of 5 (permalink) Old 07-16-2006, 10:38 PM
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6.
Quoted: 989 Post(s)
Beautiful car. My Fathers friend in Germany still has his in 1960 bought 220 SE coupe with a total of under 80,000 km.
Teutone is offline
post #4 of 5 (permalink) Old 07-20-2006, 06:57 AM
Date registered: Jun 2004
Quoted: 5 Post(s)
Nice car,the driving lights are the same as I have on my 6.3 .
initially I thought the The engine you have is the same unit that was fitted to the Unimog S404(M180) but you have the M127? .The low compression is acheived by having a larger combustion chamber volume,you can tell the difference by measuring the thickness of the head on the outside.
To raise the compression get a head from a European ( or South African or Australasian ) delivered car.The cams are vastly different too,so using the low compression cam would be a retrograde step.There are several diffrent M127 cams which can be told apart by the numbers stamped on the rear.
mercmad6.3 is offline
post #5 of 5 (permalink) Old 07-20-2006, 10:54 AM Thread Starter
alydon's Avatar
Quoted: 45 Post(s)
Yes, my engine is a 127(.984?). I will be restoring the drivetrain within the next year or two and will definitely want to increase the HP. Could I not just shave the head to increase the HP? Obviously the cam issue would also need to be addressed. Not sure why I woudl have to get a different head, though.
Al
alydon is offline
    W111 280SE Coupe shocks james cleary Vintage Mercedes-Benz 2 06-09-2006 10:04 AM
    '61 W111 220SEb coupe restoration heckflosse_uk Vintage Mercedes-Benz 20 03-07-2006 02:31 AM
    on a quest to find a 280se coupe or 250se coupe..w111 bodystyle ventura250s Vintage Mercedes-Benz 3 06-01-2005 09:33 PM
    W111 Coupe/280 Engine...Parting out! wdb123 Vintage Mercedes-Benz 0 10-28-2004 10:03 AM
    Check out this beautiful W111 Coupe... Norb Vintage Mercedes-Benz 4 10-12-2004 04:59 PM
