Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 07-09-2006, 05:09 PM   #1 (permalink)
Date registered: Jun 2006
Clutch Slave Cylinder Problem
Hi,
I'm replacing the clutch slave cylinder in my 75 240D, but I think they used the same part in many models. Anyway, I can't figure out how to replace the fluid. Does anyone know where/how to put the fluid in and where/how to bleed it? Thanks a lot for any help.
its the first item on this page, you can click it to enlarge
http://replacement.autopartswarehous...linder&dp=true
Additional Bonus Question: When replacing the oil filter, does anyone know which way the fine mesh filter should face? I'm talking about the disk that sits on the top of the oil filter- words up or down? Thanks!!!
Sizzle-Chest is offline   Reply With Quote
Old 07-10-2006, 01:45 PM   #2 (permalink)
KCM
Date registered: Jun 2004
Some models have a small round reservoir under the hood next to the brake reservoir, while others tap into the brake reservoir and use the same fluid. Don't know which way yours is.
As far as bleeding, you need to fill the reservoir and loosen the bleed screw on the slave cylinder with the clutch pedal up. Fluid should flow down and push the air out. When only fluid comes out, tighten the screw and it is bled.
KCM is offline   Reply With Quote
Old 07-15-2006, 09:34 AM   #3 (permalink)
thanks KCM. for anyone searching this information about the 240D, the brake resevoir is divided into two sections. the one closest to the firewall is for the clutch.
