'76 450 sl won't stay running - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 06-27-2006, 07:04 AM Thread Starter
squirrel_master's Avatar
Date registered: Jun 2006
I have also posted this on the 107 section...mods, please don't pull this!
I recently acquired a '76 450sl that has been sitting for a couple of years. I drained all the old gas out, blew out the lines, and put in fresh fuel. The car will start right up and run for a few minutes, but as soon as the engine starts to get warm it wants to die. I have about 90 pounds of fuel pressure coming into the distributor. I have not yet checked the control pressure and I am working on building an adapter so I can. I can tell you all of the injectors seem to flow well, and the piston in the fuel distributor moves freely. After 5 minutes or so of running, the engine won't take any throttle. It will idle roughly and eventually die. It will start right back up, but wants to die right away. Any thoughts on this one?
squirrel_master is offline
post #2 of 5 (permalink) Old 07-02-2006, 06:57 AM
Date registered: Jun 2004
Quoted: 5 Post(s)
you must have a guage to test the pumps pressure,so what it is the pressure on the return side?
Have you checked the igniton.Could be fualty coil too.
mercmad6.3 is offline
post #3 of 5 (permalink) Old 09-08-2012, 11:56 AM
Date registered: Sep 2012
i have the same problem with my 77 450sl, it sat for 4 yrs, drained the gas, changed the fuel pump and filter, changed plugs, changed the fuel pressure valve, cold start works, when I bleed the line to the fuel distibutor, it seems to run good for a while, than dies.
casamont450sl is offline
post #4 of 5 (permalink) Old 09-08-2012, 06:46 PM
you may have a vacume problem, first change your fuel filter, than on your fuel pressure valve remove air hose on bottom, if it dies your ok, if not find your leak.
post #5 of 5 (permalink) Old 09-16-2012, 06:44 PM
Date registered: Sep 2008
Vehicle: 1975 450SL
Quoted: 15 Post(s)
Go over to the 107 forum here: R/C107 SL/SLC Class - Benzworld.org - Mercedes-Benz Discussion Forum . Read the sticky topic labelled Encyclopedia Germanica v107. There is a LOT of info there that may help you out. Pay attention to the info on K-Jet injection systems.
RadioTek is offline
