300 SEL 4.5 water pump removal - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 06-12-2006, 01:00 PM Thread Starter
Date registered: Oct 2004
Vehicle: 1980 6.9, 1977 6.9, 300SEL 6.3, 300SEL 4.5, 300TE, 560SEL, 560SL, AMG models
Without a manual, it appears that I will need to remove the distributor as well as many other pieces to replace the water pump (seized from non-use) on this A/C equipped model. Anyone else done this? Looks like a bear of a job. Any wise shortcuts would be appreciated!
unpolire is offline
post #2 of 7 (permalink) Old 12-15-2006, 08:00 PM
Date registered: Dec 2006
water pump replace
hi. it looks like i have same problemwith my 280 sel 4.5 did you ever find a solution
or help . mine looks like i'll have to pull damper and crankshaft pullies. can you or anybody help!!!!
thanks . "my backs tired already", Bryan.
bryan72mb280sel4.5 is offline
post #3 of 7 (permalink) Old 12-15-2006, 08:04 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 712 Post(s)
I've never done it, but I know it's a bear of a job...
GeeS is offline
post #4 of 7 (permalink) Old 12-15-2006, 08:15 PM
water pump replace
hi thanks for the reply .. could you tell me if i might find repair procedure or
help online??
thanks, Bryan.
post #5 of 7 (permalink) Old 12-16-2006, 03:32 PM
Date registered: Jun 2006
Vehicle: 1981 300CD, 1973 280C
I did this on my 72 280SEL 4.5 years ago. Removed fan blade and shroud, removed bolts holding small water pump to front of engine. Was necc to rotate crank pulley, if I recall, because there was a cut out on it to access lower bolts. I think I loosened the alternator to get belts off. I know for a fact, I did not pull the crank dampner off. My memory recalls it being rather easy, like replacing a water pump on an early 440 Chrysler. Mid 70's. My bearings had failed and the pump seized because the impeller was cocked over. It happened in of all places the local MB dealers parking lot! Called a tow truck and towed it to my house.
carnut1 is offline
post #6 of 7 (permalink) Old 12-16-2006, 05:50 PM
Smile thanks
hi ,thanks for the info.. I'll check that out .
hope that'll work .i wasn't looking forward to what i had in mind.
once again thank you . Bryan.
post #7 of 7 (permalink) Old 12-20-2006, 08:14 AM
Date registered: Sep 2006
Vehicle: Many MBs
You should find procedure somewhere on this site. I'll give you some tips though. The previous poster was able to take advantage of holes in the balancer. That doesmn't always work. You may need to remove the balancer. If you do paint a line across the balancer and all the pulleys to mark them. Also you only remove the 6 bolts or so to remove the pulleys. You do not need to remove the 27mm bolt in the middle of the crankshaft. I've seen this mistake made often. You''l need a couple of pry bars to walk the balanced off the shaft. Good luck.
autozen is offline
