1979 450 SL engine knocking/right side - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 05-18-2006, 02:50 PM Thread Starter
Vehicle: 1979 450 SL
Question 1979 450 SL engine knocking/right side
Recently purchased vehicle with app 80000 miles has knocking similar to valve clicking in right side of engine, but mechanic says cause of noise cannot be adjusted and that the source of the noise may be from a wrist pin. He also says engine could run like that for 100,000 more miles, but the noise is annoying. Any suggestions?
tewamoore is offline
post #2 of 8 (permalink) Old 05-18-2006, 05:57 PM
W2013,2's Avatar
Vehicle: 190E 3,2 / 560 SEC / 250-W113 - groop 6 Race car and other
Hi be carefull
you have a problem with the Valves on one side, you have to check the Valves
the are not Hydrauliksystem in your Engine it works Mechanikal.
Gottfried
W2013,2 is offline
post #3 of 8 (permalink) Old 05-24-2006, 11:29 AM
KCM
Date registered: Jun 2004
Quoted: 17 Post(s)
I'm fairly certain your car has hydraulic valve lifters. I worked on a 1975 or 1976, and remember reading that the next year Mercedes went to hydraulic. It is true and not true that there is no adjustment. There is no major adjustment, but there are shims on top of the valve stems that adjust the lifters to get them all to the same height from the head. If they are not hydraulic, then they definitely can be adjusted, and should be.
I doubt the shims are an issue here, but it is possible a hydraulic valve lifter has gone bad and has collapsed. It does happen, and they are replaceable. A good mechanic can take the valve cover off and check each to make sure it is working properly. The wrist pin noise is possible, but sounds like he is just guessing. There is a tool that looks like a stethoscope that can be used to pinpoint the location of a noise without guessing.
KCM is offline
post #4 of 8 (permalink) Old 05-24-2006, 12:12 PM
Djenka018's Avatar
Date registered: Jan 2005
Vehicle: '80 450SLC Afro RHD Ikonengold
Quoted: 56 Post(s)
Camshaft oil supply rail over the camshafts have tiny hiles where oil drips on camlobes. Usualy, holes get clogged and it starves lobes to dry condition. Metal on metal and no lubricant = valves start knocking.
Must do:
1. NEW plastic feeder on coper-like oil supply rail
2. good clean of same rail, holes too (3M makes good products for this, I would not use sandpaper)
3. You'll have to replace rockerarms and camshaft as needed but pointless to do unless 1. and 2. not done.
I've done it on both banks. :-(
Djenka018 is offline
post #5 of 8 (permalink) Old 05-25-2006, 11:42 AM
Date registered: Apr 2006
Vehicle: 1978 Mercedes 450SLC , 1992 Mercedes 400 SE , 1999 Jeep Grand Cherokee Limited
Same Problem
Hello,
It sounds like I may have the same problem that you are experiencing. I have a 1978 450SLC and I have been hearing a tapping noise from the right valve bank. Is it possible to visually inspect the camshaft supply rail by just removing the valve cover? How would you recommend I would proceed with determining if that is indeed the cause of the noise.
Thanks in advance.
CoreyH is offline
post #6 of 8 (permalink) Old 06-09-2006, 06:08 AM
Vehicle: 1998 sl500 Sport, 2008 e350
if you're sure its on the right side, take the valve cover off and start the engine. you should be able to pinpoint which valve is making the noise. doing this will also let you see if the camshaft supply rail is actuall oiling the cam lobes
rwolak@verizon.net is offline
post #7 of 8 (permalink) Old 06-09-2006, 05:08 PM
Quoted: 5 Post(s)
Diagnosing wrist pin noise
..is simple,using rubber gloves or insulated pliers,just remove each plug connector in turn until the noise stops.If it doesn't stop the noise ,it's either tappets ,worn chain and tensioner rails or a cracked Piston .
in any case,ANY noise is of concern.The engine should idle smoothly and quietly with no noise what so ever.
This what happens when you ignore noises in a Mercedes V8...thats a valve head on the right hand side stuck in the broken remains of the piston.
mercmad6.3 is offline
post #8 of 8 (permalink) Old 07-22-2010, 10:30 PM
Date registered: Jul 2010
Vehicle: 1979 Mercedes 450 SL
my 79 450sl just started doing this same knock today. i have been slowly rebuilding the car and just put a replacement distributor in it today because the advance was bad on the old one. car fired right up and actually idled for the first time without my foot on the gas. after about five minutes the car shuttered and then started knocking from the right side and then stalled. It restarts and stays running if you keep your foot on the gas a little bit but is still knocking. Any suggestions on the sudden onset of knocking and why it wont idle?
mb450boy is offline
