w115 odometer stopped working - Page 2 - Mercedes-Benz Forum
post #11 of 11 (permalink) Old 05-25-2006, 11:42 AM
mjlehner's Avatar
Date registered: Apr 2005
Vehicle: 1972 220D 4 spd man
The cluster on the 220 (w115) is held in by a jam gasket. Not sure what the right word is for it but it's a gray piece of vinyl/rubber that encircles the two large guages and literally just jams them in. Nothing else holds them in place except for the wires, etc. from behind. You can work the cluster loose, turn it sideways and disconnect what you need to in order to remove it. To replace, you just fit the jam gasket around the cluster and "jam it in" to where it's solid. Be sure to re-connect everything first and that's about it. Check your dash lights dimmer knob as well, prior to dis-assembly. If your dash lights dim nicely and brighten back up at the turn of the knob, no worries. But mine was flickering and/or not working. There is a potentiometer back there that you can clean up while you are in there.
They don't make anything like they used to. In fact, they never did.
mjlehner is offline
