SLC Rear Window Defroster - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 03-02-2006, 03:07 AM Thread Starter
B-McD's Avatar
Date registered: Aug 2005
Vehicle: '79 450 SLC
Send a message via MSN to B-McD
Upon removing my rear window, for rust reasons, I found that the thin flat wire running around the edge of the window was gone as a circiut, no reading at all. It was evident visually too, dirty and off track. Should it be simple enough to use a wire of same or similar resistance to wrap around the window edge and tie down with electrical tape to fix it? Or will it be more complex? Thanks in advance.
B-McD is offline
