» Sponsor Links
»Garage Storage and Cabinets
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 02-19-2006, 03:32 AM   #1 (permalink)
Date registered: Feb 2006
75 230 Auto won't come out of park??
I just got a 75 230, 6 cylinder, 140K with a auto tranny that has been on blocks and hasn't run for 8 years. I made it run but the starter will only turn over the motor once in while and it will just spin up sounding like the starter bendix is bad?? I can't get the car out of gear? I looked at the manual and it shows the shift pattern but the streering column mounted shifter will not budge. I have tried it running, not, running, ebrake/brakes on/off, etc. I don't want to force it and I have even jacked the car up in the rear and rocked the wheels back and forth to try and un jam the linkage if it was jammed. What really stumps me is that with the car in park and the rear wheels off the ground if I turn the rear wheel hard enough it will turn the wheels even though the tranny is in park? Anyone have any ideas?? Benzs are new to me so I am clueless about them. Sorry for the long post
redlines is offline   Reply With Quote
Old 02-19-2006, 06:04 AM   #2 (permalink)
RE: 75 230 Auto won't come out of park??
From one BW newbie to another!
If both rear wheels are off the ground, it is possible to turn one wheel with the other turning the opposite direction if you have a standard differential. Are you sure it is an automatic? I thought a 75 auto would have a floor shift. Both the 76 and 77 diesels we owned had floor shifters. The 71 had a column mount manual shifter.
As a mechanic may I suggest: Don't force anything! Someone will know how to fix it.
Have a nice day
Steve
smcmanus is offline   Reply With Quote
Old 02-19-2006, 01:51 PM   #3 (permalink)
Yeah there is no clutch and it has a auto tranny dipstick and a gear shift selector lever on the column by the shifter. Thanks
Old 02-19-2006, 04:13 PM   #4 (permalink)
~BANNED~
AMSOIL300CDT's Avatar
Date registered: Jan 2005
Vehicle: 85 C123 TurboDiesel, 87 190e 2.6
Location: Heilbronn am Neckar, Baden-Württemburg, Deutschland ; Ft. Myers Beach, Florida, USA
Send a message via AIM to AMSOIL300CDT
normally i would guess that the linkage is sticking, while, physically seen, u HAVE to move the whole works, in order for it to shift at all.....in other words, the handle must be jammed......
but im probably wrong, so hang in there....[:0][:)]
AMSOIL300CDT is offline   Reply With Quote
