Wheel paint question - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-22-2006, 10:36 PM Thread Starter
~BANNED~
Autobahnfahrer's Avatar
Date registered: Oct 2005
I stripped and repainted a set of bundt rims for my MBZ. I painted them in the original "argent" silver and they look excellent. Now the question is do I clear coat them, or do I let them sit as is? The paint directions mention that it is optional to wet sand and clear coat. I am just concerned about peeling down the road. Does anyone have experience with this? Thanks!
Autobahnfahrer is offline
post #2 of 3 (permalink) Old 01-23-2006, 05:07 AM
Prochambers's Avatar
Date registered: Jan 2004
Vehicle: 1987 420 SEL
Quoted: 12 Post(s)
RE: Wheel paint question
I did my 15 hole wheels last summer and yes I did add the clear coat on them. Even now in this winter rain and cold, they look great when cleaned up.
If you lend someone $20 and never see that person again, it was probably worth it.
Prochambers is offline
post #3 of 3 (permalink) Old 01-25-2006, 01:50 PM
Riquiscott's Avatar
Date registered: Aug 2005
Vehicle: 1972 250C, Ducati ST
I would advise clearcoating them as well. As long as they're properly cleaned and prepped, you shouldn't have problems with flaking or peeling.
Wet-sanding wheels can be tricky, since with all the cracks and crevices, it's easy to accidentally sand down through the paint to the primer or the underlying metal. As long as you're happy with the quality of the silver finish, you can just wet-sand the easy-to-reach places and then clearcoat the whole wheel.
Also, if you're mixing the clearcoat yourself and applying it with a spray gun, use a "faster" reducer than you would normally use for the ambient temperature. Parts with a lot of nooks and crannies are more prone to drips, runs and sags, and a faster reducer will help the paint set up more quickly.
Scott
Riquiscott is offline
