Self Leveling Oil - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 12-05-2005, 08:26 PM Thread Starter
Vehicle: 450SEL (4.5)
Self Leveling Oil
Hi all,
I am new hear and I have 3 450SEL's (4.5),
2 of them are for parts,and the other I drive,none are for sale,yet.
I am looking to fix the rear leveling mechanisms.
I have replaced the bar that goes to the back and connects to the valve because it snapped !
But I cannot find the correct oil to use for the canister in the engine bay.
Someone mentioned I can use any automatic transmission oil, or Hydraulic-Jack oil if I ever get stuck.
I am also looking to read something on the correct procedure to adjust the rear leveling valve after I find the correct oil.
The people at a spare parts counter did not understand about MB Self leveling, and I am finding in most cases the mention of MB shows a "fear" in their face.
But I will not drive anything else but my 450SEL
Nice car, but I have only had these cars for a little over 3 months and discovering new things all the time.
I have to fix the oil problem first though.
Nutz450 is offline
post #2 of 5 (permalink) Old 12-05-2005, 11:35 PM
Boring Cars...meh!
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: 81 280E, 84 500SEC, 87 560, 89 "300E", 91 500SL, 15 E350 4Matic Estate, 71 BMW 2002, +others
Quoted: 16 Post(s)
RE: Self Leveling Oil
Aral 1010
Shell aero fluid 4
Shell tellus T17
Gasolin 1010
Nutz 4 Benz is offline
post #3 of 5 (permalink) Old 12-06-2005, 06:27 AM
uberwgn's Avatar
Date registered: Jul 2005
Vehicle: 1998 E300D
The MBz (FEBI) fluid is not that's around $8/L.
1998 E300D
uberwgn is offline
post #4 of 5 (permalink) Old 12-06-2005, 09:27 AM
DP's Avatar
Vehicle: 190E, 400E, SLK350
Quoted: 983 Post(s)
I would bet that it takes the same oil that my sel takes. It's not that expensive, just get it from the dealer.
DP is offline
post #5 of 5 (permalink) Old 12-07-2005, 03:56 AM Thread Starter
I did some towing after the first post, actually I helped a fellow BenzNut re-locating their 6.9's.
The leveling did not work with all that weight so I know I have some work to do. The hose from the pump to the side of the engine ruptured, no big deal.
Having said this, I need to know how do I correctly adjust the valve mechanism on the rear torsion bar ?
I assume I place the car level on the ground and just play around with height while the engine is idling and then tighten up the 9ml nut on the U-Bolt ?
Just need that clarified and all the rest is straight forward.
Have plenty of spares so not a worry.
Once again, thanks for your replies.
Nutz450 is offline
