w108 distributor has oil in it !! - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-29-2005, 06:58 PM Thread Starter
Date registered: Nov 2005
Vehicle: 1972 280se 4.5L
Hello , I have a 1972 280se 4.5 that was running very well until just recently.
I have been over this engine thoughroly in the last yr. New plugs,points,coil, intake gaskets and I also removed the distributor and cleaned it up along with the trigger points.
All was going well until recently some oil vapor came in thru the distributor (shaft?) and fouls the points making it miss and backfire.
Can you rebuild a distributor or get a factory rebuilt one with fresh seals and so forth?
Do you all have any ideas or fixes? Besides this it runs like a bat-outta-the-fatherland!!
I also replaced the thottle position switch on the throttle body. I am not sure if the is a proper placement of this I just placed it back in the most 'neutral' position .
Thanks for any help. Mitch
" To faith and virtue we make promises , fear and pain we obey."
MLADYMAN is offline
post #2 of 2 (permalink) Old 12-04-2005, 02:34 AM
Date registered: Aug 2004
RE: w108 distributor has oil in it !!
My 1973 350 SLC (similar V8engine)also has a similar problem with the trigger points in the distributor becoming fouled. The engine runs like a dog progressively improving over about 20 mins of running - at the end of the journey she'll be purring like a cat. Its frustrating to know that each journey will begin like this - I think maybe if I drove it more often it wouldnt be as bad. I have a spare distributor and can see a rubber seal at the base of the shaft an inch or so above the gear teeth. Theres no obvious way to replace this easily. Anyone else any ideas?
Pete Moreau
Kildare, Ireland
Kildare_SLC is offline
