Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 11-18-2005, 07:30 AM   #1 (permalink)
Date registered: Nov 2005
1976 240D-W115 half-shaft (axle) replacement procedure
Hi All,
I recently purchased a 76 240D-W115-auto. The mechanic installing new tires discovered a torn right inner CV boot. The left side CV boots are cracked and about to split. This shop wants $1000 to change the boots and $1400 to install rebuilt axles.
I called around to a few auto parts places and I can get rebuilt half shafts for $78. My problem is that I can't find any auto repair places to install parts I purchase. So I've been giving very serious thought to installing rebuilt axle shafts on my own.
So is replacing an axle shaft a huge pain in the ass? The procedure I'm planning on attempting is as follows:
1) jack/block up car
2) remove tire
3) remove brake caliper by removing the two 19mm bolts on the back of caliper
4) remove small bolt on end of wheelshaft and remove rotor
5) somehow remove axle shaft from remaining wheel assembly
6) drain differential
7) remove rubber differential mount
8) open differential case and look for axle retaining clip and remove
9) pull out axle shaft from differential
The step's I'm most concerned with are #'s 5,8,& 9.
Concering step #5- I'm not sure what exactly I'm looking for or the torque involved to get the axle shaft out of the wheel.
Concerning step #8 - I'm sure something has to hold the axle shaft in the differential, I'm not sure if a special tool is required to remove.
Concerning step #9 - I'm not sure how much torque is required to remove.
I would be grateful if someone could give me a few pointers before I attempted this project. I'd really hate to get things torn down and realize I need special tools to get the axle shafts out.
Kind Regards,
The 240Dork [}:)]
240Dork is offline   Reply With Quote
Old 11-22-2005, 06:29 AM   #2 (permalink)
Date registered: Sep 2005
Vehicle: 1970-200 1983-230e
RE: 1976 240D-W115 half-shaft (axle) replacement procedure
You're right about the clip in the diff, the axle is just a press fit onto the hub. The most difficult thing is to undo the caliper...The 19mm bolts are quite shallow and slip easily if you don't have really good quality sockets and/or air tools.
Anil
anilv is offline   Reply With Quote
