1971 300sel - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 10-31-2005, 02:13 PM Thread Starter
Vehicle: 1983 300td
1971 300sel
I'm usually in the 123 post...mostly for my 2 1983s 300td. Lately I've been looking at a particular 1971 300sel 4.5 - "dead" for the last 6 months. Symptoms - choke stays on even after warm up period - resulting in stalling engine and black smoke coming out. Also,...of course, since it's been sitting for 6 months, the front wheels are all the way down. No rust. Is this a car worth $500. Sorry, I'm a diesel fan but I love the look of the 109 series also.
Just wanted to ask you folks. Thanks.
Winston is offline
post #2 of 9 (permalink) Old 10-31-2005, 02:16 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
RE: 1971 300sel
For $500, you can part it out and do just fine.
flyboyike is offline
post #3 of 9 (permalink) Old 10-31-2005, 03:46 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 714 Post(s)
RE: 1971 300sel
Exactly, you could get that the fenders alone if they're nice.
GeeS is offline
post #4 of 9 (permalink) Old 10-31-2005, 03:53 PM Thread Starter
Vehicle: 1983 300td
RE: 1971 300sel
I'm not looking to buy this 300sel to part out, I'm looking at hopefully making it a part time driver....but however, I'm new to this post and won't know if it's really true, it's a money pit like a few have said....or if they are truly going to be a collectable. This is a 4.5 engine....but the engine was swapped with a wrecked one a few years ago. Looking to see if it's better off as a parts car or restorable. Thanks.
Winston is offline
post #5 of 9 (permalink) Old 10-31-2005, 03:56 PM
flyboyike's Avatar
Quoted: 69 Post(s)
RE: 1971 300sel
Winston - 10/31/2005 5:53 PM
Well, let's see some pics, but, yes, these are money pits. Just the air suspesion could set you back numerous thousands to rebuild.
post #6 of 9 (permalink) Old 10-31-2005, 04:13 PM Thread Starter
Vehicle: 1983 300td
RE: 1971 300sel
Wow, it's definitely not like the 123's where parts are readily available.
Winston is offline
post #7 of 9 (permalink) Old 10-31-2005, 04:24 PM
flyboyike's Avatar
Quoted: 69 Post(s)
RE: 1971 300sel
Winston - 10/31/2005 6:13 PM
Oh, they are available just fine. Just a lot pricier.
post #8 of 9 (permalink) Old 11-01-2005, 12:03 AM
Date registered: Jan 2005
RE: 1971 300sel
For suspension help etc go to the m-100 site at www.M-100.cc ,but 4.5's are fuel injected and DO NOT have a choke,They are electronic Djetronic .If it is running rich it can be : leaking starting injector,blocked aircleaner,fualty water temp sensor,Fuel pressure regulator set too high or fuel return pipe to and In the fuel tank blocked,Manifold air pressure sensor diaphram ruptured,throttle position switch out of adjustment or soe one has turned the idle control on the ECU .
mercmad is offline
post #9 of 9 (permalink) Old 11-02-2005, 05:05 PM Thread Starter
Vehicle: 1983 300td
RE: 1971 300sel
Thanks for the information Mercmad and the rest! I'm just going to wait to see what the seller wants to do. No reply yet...probably sold to a chop shop.
Winston is offline
