HELP - buying advice... and then running advice 72 280SE 3.5 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-17-2005, 04:59 AM Thread Starter
Date registered: Oct 2005
So I have been watching for a 280se for literally a couple of years on and off. (Previoulsy I was into old VW's). I live in the UK and really wanted a car with Air cond which has finally come up. However the car also has an engine fault which the seller (Owner for the last 10 years) says he believes is a sticking valve. I have had this work priced locally (Bout £1k for two recond heads fitted part exchange)
Is there is anything else I should specifically be interested in on this model? Questions I should ask?
Any help gratefully received.
Also anyone suggest a UK supplier for mechanical parts like exhaust/brakes etc?
skills2paythebills is offline
post #2 of 2 (permalink) Old 10-17-2005, 01:58 PM
Date registered: Jan 2005
RE: HELP - buying advice... and then running advice 72 280SE 3.5
Never heard of a sticking valve because that engine will have valve rotators.
I would suggest that you get a "leak down " test done.NOT a compression test.
3.5 heads are RARE!
I know because i have two sets here and have received wild offers for them from all over the world....and i've never advertised them.
In a 3.5 the first thing is to do if you've actually bought the car,is get the timing chain changed,change all the fluids,replace the fuel filter and ALL EFI hoses from the gas tank forward.They run at 28PSI and it's common for the old hoses to leak and spray hot fuel over the engine....[}:)]
Get the igniton overhualed,i find it easier to pull the distributor and check the trigger points in the bottom at the same time,sealing them in with silicone.
New plugs ,points and condensor and a check for resistance in the leads should get rid of any gremlins .
With your leak down check done,new igniton and all the hoses for the efi sorted,with clean oil ,tranny fluid and brake fluid it should be OK to run.You can now start chasing fualts in the Djetronic...
If it were mine i would also get the radiator flushed because i suspect that you have a corroded head ,that's what is causing the miss.The block and radiator will be full of crap because of this.All the coolant hoses will be shot ,and really should be replaced every six years but it's not unusual to find them on cars when they are 30 + years old.
Parts should be easy to buy from any Merc Dealer near you or any large motor factor in the UK.Especially one that deals in Euro cars such as VW Porsche etc
mercmad is offline
