Reverse lights - problem or "Benz-ism"? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-14-2005, 07:27 PM Thread Starter
Riquiscott's Avatar
Date registered: Aug 2005
Vehicle: 1972 250C, Ducati ST
I'm still learning about the various features and behaviours of the 1972 250C I bought a few weeks ago. Here's the latest:
The reverse lights come on when I shift from "Park" to "Reverse", but not when I shift from "Neutral" to "Reverse". It behaves this way 100% of the time, almost like it's designed that way. If I go from Neutral to Reverse, no amount of wiggling the shift lever will cause the reverse lights to come on, but they come on every time when I shift into Reverse from Park.
If this isn't normal, is there any kind of adjustment for the reverse-sensing switch, or should I just replace the switch?
Thanks,
Scott Gardner
Riquiscott is offline
post #2 of 3 (permalink) Old 09-14-2005, 07:35 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 68 Post(s)
RE: Reverse lights - problem or "Benz-ism"?
Methinks, you're gonna be needin' a switch. It should turn those lights on whenever the shifter is in "R", no matter where the shifter was previously.
flyboyike is offline
post #3 of 3 (permalink) Old 09-14-2005, 09:12 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 665 Post(s)
flyboyike - 9/14/2005 6:35 PM
Agreed -- common enough...
GeeS is offline
