Windshield stain removal [How to?] - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 09-13-2005, 05:46 PM Thread Starter
Date registered: Sep 2004
Vehicle: W114 230.6
My front windshield has a white stain (it looks milky) around its edges, from the very edge to 3 to 4 centimeters towards the center. Any ideas what might have caused this and how to fix it?
Odrec is offline
post #2 of 6 (permalink) Old 09-13-2005, 09:46 PM
Boring Cars...meh!
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: 81 280E, 84 500SEC, 87 560, 89 "300E", 91 500SL, 15 E350 4Matic Estate, 71 BMW 2002, +others
Quoted: 17 Post(s)
RE: Windshield stain removal [How to?]
Nothing you can do about the "stain". What happened is the windshield is delamenating allowing water to
get in between the glass.The best preventive measure would be when you replace the windshield replace the seal.
http://i30.photobucket.com/albums/c328/nutz4benz/W123/6C3A9CA5-EDFF-4834-8125-34B70B20A676_zpsiyesrawz.jpg
Nutz 4 Benz is offline
post #3 of 6 (permalink) Old 09-13-2005, 10:46 PM
SalvageTitle's Avatar
Date registered: Sep 2005
Vehicle: 74' 450 SE
Send a message via AIM to SalvageTitle
if it's on the outside of the glass... glass cleaner and 00 steel wool will remove contaminants on your glass, if that doesn't work use rubbing alcohol and 00 steel wool. worth a shot, and you can find the steel wool at most hardware stores or online at an auto detail websites.
SalvageTitle is offline
post #4 of 6 (permalink) Old 09-13-2005, 11:17 PM
Riquiscott's Avatar
Vehicle: 1972 250C, Ducati ST
I agree that it's probably moisture that's seeped between the layers of safety glass. If you want to confirm it, try carefully heating part of the affected area with a hair dryer or heat gun. If the "milkiness" fades briefly, then it's trapped moisture. Problem is, once the glass has started to de-laminate, the moisture will always come back. Replacement with a new windshield and seal is the only sure fix.
Scott
Riquiscott is offline
post #5 of 6 (permalink) Old 09-21-2005, 10:34 PM Thread Starter
Vehicle: W114 230.6
I guess if it is a laminating problem I'll have to change it. MB's have a hard time with the usual 100% humidity of the tropics!
Odrec is offline
post #6 of 6 (permalink) Old 11-09-2005, 03:18 PM
Date registered: May 2005
LET ME TELL YOU HOW TO FIX IT VERY EASY AND NEAT WAY.
1. GET YOUR WIFE'S HAIR DRYER
2. FIND AN EXTENSION CORD AND HOOK IT UP TO POWE WHERE YOUR CAR IS
3. TURN IT TO HIGH POWER BLOWER MODE MAKE SURE THAT IT IS HOT
4. GENTLY WITHOUT GOING TOO CLOSE TO THE WINDSHIEL HEAT UP THE MILKY AREA
5. TAKE YOUR TIME DO NOT HURRY OTHERWISE YOU WILL CRACK THE WINDSHIELD FOR SURE
6. IF YOU DO IT TAKING YOUR TIME AND MAKING SURE THAT YOU DO NOT HEAT UP ANY SPOT MORE THAN YOU WILL SEE MIRACULOUSLY THE MILKY SPOTS ARE GONE.
NOTE: I SHATTERED MY WINDSHIEL WHILE DOING IT BUT, MILY SPOT IS GONE. THE TRICK IS IN THE HAND YOU DO IT LIKE SPRAYING PAINT. I WAS IN A HURRY.
BENZ260SE is offline
