» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
BenzWorld.org is the premier Mercedes Benz Forum on the internet. Registered Users do not see the above ads.
Old 08-08-2005, 01:00 PM   #1 (permalink)
Date registered: Jun 2005
Vehicle: 72 250C
1972 250C speedo cable
I picked up a 72' 250C that had been sitting in a barn for the past 20 years for $1,200. It is in great condition(never wrecked)with a little rust in the trunk area and around the battery box. After cleaning the fuel tank and replacing the old rubber brake lines I started it and drove it about 175 miles home. It has been a great running car. My speedometer broke last week and I need a new cable. I don't want to order one from the dealership because of the huge prices they charge. Can anyone tell me if it is possible to just by the inner cable and if so where? This is a great website. Glad I found it. Thanks
dkinslow is offline   Reply With Quote
Old 08-08-2005, 04:02 PM   #2 (permalink)
MB250's Avatar
Date registered: Jun 2004
Vehicle: 1971 Mercedes 250
RE: 1972 250C speedo cable
I take it you have the old speedo cable off because I had the dealer replace mine and it turns out that the actual speedometer is at fault, the speed indicator still worked but the trip meter and the odometer didn't work. You could try a salvage yard or search google. Just a thought[:)]
MB250 is offline   Reply With Quote
Old 08-09-2005, 08:13 AM   #3 (permalink)
Vehicle: 72 250C
Thanks for the reply. I believe that you are correct that the speedo itself could be at fault because the trip meter did not work correctly and it would read about 10mph faster at any speed over 60. I have not pulled the cable to check for a break but after reading your post I will check into getting a used speedo. Thanks again.
Old 08-09-2005, 04:03 PM   #4 (permalink)
MB250's Avatar
You could also have the original one rebuilt, I found this guy on the web and I plan on having him rebuild my speedometer aswell as the clock.
http://www.speedometer.com/index.html
If you wanted to get a brand new speedometer it's rather expensive through these guys but it's new.
www.adsitco.com
Goodluck
Old 09-22-2006, 09:38 AM   #5 (permalink)
ldshull's Avatar
Date registered: Jan 2006
Vehicle: 1973 280sel 4.5
Send a message via Skype™ to ldshull
Question speedometer troubles
I'm having some speedometer troubles as well. Both the speedometer and odometer stopped . 1973 280sel 4.5
Did you find a solution to yours? Did you contact that speedometer website?
Thanks
ldshull is offline   Reply With Quote
Old 09-22-2006, 09:54 AM   #6 (permalink)
Date registered: Jun 2006
Vehicle: 1981 300CD
If both quit, I would suspect the cable. The odometers quit because the plastic gears slip on the shaft. The speedo cable can be broken? disconnect the cable at the trans and spin the inner cable to verify the needle moves.
carnut1 is offline   Reply With Quote
