Burning HOT Preresistors - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 07-12-2005, 09:28 AM Thread Starter
Captain Scott's Avatar
Date registered: Apr 2005
Vehicle: 1974 450 SL
I just burned the Bosch symbol into my finger tip!
After leaving the ignition on for about 5 minutes and having not run the car at all, I felt heat coming off the two preresistors and smelled that unfriendly hot electrical smell. Smartly, I pressed my finger on the bracket that holds it and realized too late that it was not a good idea. No wires show any melted or chared insulation. The coil is warm and no other wiring seems to be unduly hot. The Ignition Control Module in the left wheel well seems only slightly warm. And the car seems to run fine, except for some odd beahviour (tach jumps, rough idle sometimes) that I have been chasing for a while now. My other posts have looked into those...
My friend who is fairly knowledgable with mercs (I thought I was...) said that this in not an abnormal condition, but I cannot believe it. No electrical components should ever normally run that hot unless there is some other condition ocurring or the resistors are about to go.
Why would they be hot enough to leave a burn on your finger (no blister yet)?
Scott
Captain Scott is offline
post #2 of 2 (permalink) Old 07-14-2005, 02:00 AM
benzboyz's Avatar
Date registered: Jun 2005
Vehicle: W124/230E, W202 C240 stationwagon, W210 E280 facelift
RE: Burning HOT Preresistors
The pre resistors for your ignition coil normally gets hot even whe the ignition is just turned on. current flows from the resistor thru the coil so this will make the resisitor warm.
benzboyz is offline
