1967 230 - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 06-27-2005, 08:06 AM Thread Starter
Date registered: Jun 2005
I recently purchased a 1967 230, and I am trying to find a couple of places to buy parts. Suggestions??
Cosmo is offline
post #2 of 4 (permalink) Old 06-27-2005, 06:14 PM
MB250's Avatar
Date registered: Jun 2004
Vehicle: 1975 Mercedes 300D
RE: 1967 230
A few good places
www.autopartsauthority.com
Try ebay and search for parts (www.ebay.com/motors)
you can also try google, that usually brings up some sites that sell parts
Hope this helps
MB250 is offline
post #3 of 4 (permalink) Old 07-23-2008, 10:29 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 665 Post(s)
This is an old question that's come up many, many times before. Please conduct a forum search.
GeeS is offline
post #4 of 4 (permalink) Old 07-24-2008, 10:52 PM
wbain's Avatar
Date registered: Dec 2003
Auto Parts at AutohausAZ - OEM Auto Parts - Discount Replacement Parts, Resources and Car Care Tips is also good and there are many others, including the dealer. Make sure you get your chassis number. It's on a plate attached to the radiator support and stamped into the front passenger side frame rail.
It will start with 110, there will be three more numbers, then a 10, for a manual left hand drive, or a 12 for an auto. The last six are the chassis sequence number. 110.nnn-10-nnnnnn
There are grease points on all the front suspension joints so get a grease gun, a flexible hose and a grease cartridge. I use Mobil 1 synthetic grease. If you cannot get the grease to flow, use a heat gun, an industrial strength blow dryer to heat the area, and pump in new grease. The F/S joints have wide band rubber rings, or seals, to protect the joint. If they are damaged or missing, they need to be replaced.
The driveshaft has a couple and the rear axle swing axle joint has two.
Please take some pics so we can see your car. There are many knowledgable people here.
wbain is offline
