Vacuum Pump Failure, W115 240D - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-25-2005, 07:06 AM Thread Starter
Date registered: Jan 2005
Vehicle: 1976 240D
I replaced the vacuum pump diaphragm in my 1976 240D about 5000 miles ago. Just yesterday I nearly ran a stop sign when the brake pedal went to the floor. I pulled the pump apart just now and sure enough there's a tear in the diaphragm, right along the line of the large washer on the vacuum side. What would cause the diaphragm to fail so soon? What orientation should the check valves be in? Could I have put them in backwards? There might be a vacuum leak somewhere in the car since the door locks do not work, could that cause the diaphragm to fail so soon?
wmccoll is offline
post #2 of 2 (permalink) Old 06-25-2005, 02:10 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 544 Post(s)
RE: Vacuum Pump Failure, W115 240D
Check for info -- hope this helps.
GeeS is offline
