steering question for the 70's 114 - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 12-17-2004, 06:30 PM Thread Starter
Date registered: Dec 2004
I just replaced the entire front end and steering including rebuilding the gear box and a rebuilt power steering pump.Had the car aligned yet it still has a little play in the steering-is this normal for this mercedes 72 250? is there an adjustment internally?if so whats the setting? Thanks guys
chaunsy is offline
post #2 of 8 (permalink) Old 12-17-2004, 07:59 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 714 Post(s)
RE: steering question for the 70's 114
Did you just reseal the steering box or replace the sector shaft?
GeeS is offline
post #3 of 8 (permalink) Old 12-17-2004, 10:07 PM Thread Starter
dont know german star i had it rebuilt professionaly-i assume what ever that could be taken out and replaced was done but ill ask-so i take it that there shouldnt be a drop of play then?
chaunsy is offline
post #4 of 8 (permalink) Old 12-18-2004, 05:31 PM
NordStern's Avatar
Vehicle: 300TE 4-Matic 300GD
Hi chaunsy.
I allways adjust the steering gear allowing a slight play. If adjusted too tight, it will literally steer like a GAZ Volga. It just won't center correctly. That's not what we want.
It's easy to adjust it with 2 spanners on top.
Hard to say if it's too loose in your case without seeing it, but I would not have it too tight. Finish the job, and test the vehicle. You can fine tune it later.
Regards
Geir
NordStern is offline
post #5 of 8 (permalink) Old 12-18-2004, 07:53 PM Thread Starter
Thanks for the response-well its not bad-i have about and inch on each side i think before i feel some movement-this is my first mercedes-im use to restoring american cars so i know what to expect. I just wanted to make sure that after spending 1500.00 on the steering and suspnesion work that i wasnt stuck with a crappy rebuilt gear box. As for the adjustments i didnt see any on the box but then again i only looked for a sec. I think ill take your advice and leave it as is. Im more concerned now with the transmission-I found from reading these forums that the tranny on my car is archaic based on the old trannies found on the late 30's oldsmobiles. This is the one thing I dont understand-so much engineering just to cop out on the tranny? Maybe im missing something-dont know-just wish there was a book soley based on the transmissions of my model that would help with adjustments-etc-all the books I have found yet are not very informative on electrical and the tranny. Anyway thanks a lot-I really love this site-you guys have a drink on me if you ever stop into hollywood ca!!!!!
chaunsy is offline
post #6 of 8 (permalink) Old 12-18-2004, 09:10 PM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 714 Post(s)
Two inches of play is beyond spec for a steering box.
GeeS is offline
post #7 of 8 (permalink) Old 12-18-2004, 09:22 PM Thread Starter
Hey german star,
I meant its an inch on each side-so are you saying that the sterring when done right should be as responsive as any other classic car of that year?
chaunsy is offline
post #8 of 8 (permalink) Old 12-20-2004, 07:30 AM
Date registered: Jun 2004
Vehicle: 1984 w123 230ce
my '72 w115 has about 1/4" play, which I wreckon is ok... my old 123 had about 3/4" either way when I got it, so I adjusted it as mentioned above and got it to about 1/4" (movement at top of steering wheel) which I thought was ok, and it centred just fine... ...1" either way is excessive IMHO
catboy is offline
