Just bought a1962 220seb convertible - What fuel??? - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 11-20-2004, 08:13 AM Thread Starter
nwg
Date registered: Nov 2002
Vehicle: See sig!
I just bought a 1962 220seb convertible (64000km original mileage). I'm not planning on driving it much, and not at all until next spring (I live in the snow belt).
What should I use for fuel? Do I need to find leaded fuel? Do I use unleaded and add lead substitute??
What's the best solution?
Thanks
Matt
'88 560SEL (sold)
'83 380SE Euro (sold)
'62 220SEB Convertible
'58 180D (sold)
'85 300D (warm weather daily driver)
nwg is offline
post #2 of 8 (permalink) Old 11-20-2004, 09:03 AM
Vehicle: 2004 E55-1970 280SEC
RE: Just bought a1962 220seb convertible - What fuel???
I'd go with premium unleaded and add some lead substitute. Also if you're going to store it, but Stabil Fuel additive. Squirt some oil into the cylinders too.
2009 C63 AMG Silver/Charcoal
1970 280SE Low Grill Coupe 2.8 Silver/Red
Past
1999 SLK230/Sport
2001 SLK32 AMG
2004 E55 AMG
Norb is offline
post #3 of 8 (permalink) Old 11-20-2004, 02:30 PM
Storm's Avatar
Date registered: Jan 2004
Some people reccommend spraying antifreeze on the block/tranny as well, but I would never do that.
As for fuel, make sure you add some lead substitute.
Storm is offline
post #4 of 8 (permalink) Old 11-20-2004, 02:30 PM
Storm's Avatar
Storm is offline
post #5 of 8 (permalink) Old 11-21-2004, 05:06 AM
Quoted: 30 Post(s)
No need to use a lead substitute. Save your money. Mercedes has used hardenend seats since the 50's. The manual probably calls for premium fuel, but premium fuel in the early 60's is about the equivalent of today's mid-grade. I've been using unleaded in mine since I got it with no issues at all. I did use modern premium for the first few years until I was "educated" about my fuel choice. The car runs fine on mid-grade. MPG is about the same with both and there is no knocking with either one. I have not tried regular unleaded and probably won't, although lots of owners say they have no problems with it either.
Len
'59 220S Cabriolet
sokoloff is offline
post #6 of 8 (permalink) Old 11-25-2004, 12:46 AM
wbain's Avatar
Date registered: Dec 2003
There is a retard lever on the distributor for just that purpose.
wbain is offline
post #7 of 8 (permalink) Old 11-27-2004, 01:30 AM
Date registered: Aug 2004
Hello there
Fuel quality here in Ireland is generally regarded as being below that of the UK and USA. Furthermore - putting low octane unleaded petrol into older engines cant give the same results as the the fuel available when the fuel delivery/ignition system was carefully designed to deliver max performance for that time.
Recently my brother in law - a mechanic and classic enthusiast told me of a product he is fitting to his 1971 Rover P5B 3.5 litre.
http://www.fuelcat.co.uk/mainpage.html
This inline fuel catalyser apparently changes the molecular structure of the fuel enabling it to burn more fully.
He came across it through a friend who has fitted to a large S class Mercedes - his friend has put one into a high performance Subaru - performance in both was dramtically increased.
With it older engines can run on unleaded without adjustment . .
I'm waiting to see before I fit one to my 1973 350 SLC
If it works its hassle free and cheaper than lead substitute etc
Have a look yourself at the website . .
cheers
Pete
Kildare_SLC is offline
post #8 of 8 (permalink) Old 11-27-2004, 09:22 AM
grezm0nkey's Avatar
Vehicle: 67 250SE Coupe
i started with low test when i got the car, it did knock and sputter, but i didnt do a tune on the car at the time. now that i have the low test knocks some, so now i moved to mid test or high test. knocks are pretty much gone. i read thru my owners manual when i recieved it from ebay and it did mention octane at 96. i have not added anything other than injector cleaner and z-max. a general aviation mechanic swears by z-max,although its not called that in aviation lingo, sez just using the stuff on his rental airplanes frees the pistons when overhaul comes around, otherwise they are just a B!^(H to get out. also noticed the first 2 oil changes produced alot of carbon and build up in oil and filter after change. oil is clear now. i guess the fuel helped loosen crap in the induction system, valve, intake, etc.
that cat fuel sounds interesting, will bring it up with a few fellow techs at work.
grezm0nkey is offline
