72 250c M130V ignition timing help needed. - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-07-2004, 04:39 PM Thread Starter
Date registered: Nov 2004
the haynes manual and owners manual are a bit confusing, they sort of conflict. one says 4 degrees ATDC but does not explain if both vaccume lines are to be removed. the other says to remove the temp sensor so that emissions are by passed. what is the proper set up?
250c is offline
post #2 of 2 (permalink) Old 11-08-2004, 12:25 PM
architect2's Avatar
Date registered: Nov 2003
Vehicle: Mercedes 1979 280ce
RE: 72 250c M130V ignition timing help needed.
There should be a sticker or metal plate on your car with the timing specifications identified. If everything is original this may work.
Per the Mercedes Engine manual, there are lots of different timing set-ups on the different versions of 110 motors found in the 280E, however; since the previous owner installed a new engine, I'm not sure what my timing should be:
0 degrees TDC with vacuum or.
8 degrees BTDC with vacuum
One of these days I'll verify the engine vin number on the block. The engine number is hard for me to see on the bottom side of the block With the engine vin number we should be able to track down the exact timing specifications, through a reputable parts house, Mercedes Dealer, or MercedesBenz.com
architect2 is offline
