Turning on the heat in a W114.... - Page 2 - Mercedes-Benz Forum
post #11 of 17 (permalink) Old 11-09-2004, 06:07 PM Thread Starter
doc_rage's Avatar
Date registered: Sep 2004
Vehicle: 1973 280C
RE: Turning on the heat in a W114....
Thanks you two! The information is helpful and I will probably use an electrical probe I have to see if I can get power to the fan mentioned through its leads....eventually, as I don't have a garage and as the temps drop, I am less inclined to play outside.
doc_rage is offline
post #12 of 17 (permalink) Old 12-22-2005, 04:31 PM
Dr Evil's Avatar
Date registered: Jul 2005
Vehicle: '75 240D
Location: Palmyra/Hershey, Penn State College of Medicine
I know that this is late in the game, but for posterity sake I thought that I would post. Your system is likely like my '75 240D set up. The barrel fan set up in the cabin center console is for the a/c only. For heat, there is a separate fan that has an interconnect on the fire wall inside the engine (good test point). I have the same problem and notice that the a/c system is under control of the fan switch when the a/c switch is on and there is sufficient vaccume to trigger what ever it is that is making the noise inside (flap?). Just more info that I have found.
HTH
Dr Evil is offline
post #13 of 17 (permalink) Old 12-25-2005, 10:20 AM Thread Starter
doc_rage's Avatar
Vehicle: 1973 280C
No worries about lateness. Truthfully, I still haven't managed to figure it out. There is a wire bundle (black, red, white....I think, it's been a while since I've been in the car) that appears to have been cut. I'm going to be posting questions and pics as to what it could possibly be later on. I hope that it's not the lingering presence of a fan motor that used to be there. It's on the underside of the passenger side. I discovered it once I removed the underdash panel[:(]
Thanks for the additional info though!
1973 280C, Weber 38DGES carb conversion-GONE. 1983 380SEL-GONE.
doc_rage is offline
post #14 of 17 (permalink) Old 01-14-2006, 02:42 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
I had a '73 280C and the heater blower only came on when I turned on the AC ('colder' knob). After some investigation, I found that was the normal design for the car.
Grubeguy is offline
post #15 of 17 (permalink) Old 01-14-2006, 04:25 PM
Riquiscott's Avatar
Date registered: Aug 2005
Vehicle: 1972 250C, Ducati ST
On my '72 250C, the only time fans come on is when I use the rotary "defrost" knob on the dash and the A/C "colder" switch. With the A/C and defroster fans off, the only air coming from the round and rectangular dash vents appears to be force-fed from the movement of the car.
Scott
Riquiscott is offline
post #16 of 17 (permalink) Old 01-15-2006, 03:13 PM
Grubeguy's Avatar
Quoted: 99 Post(s)
Looking thru the CD Rom manual I kept, there's an interlock that gets actuated when you turn the AC on - it's required to get the heater blower motor going.
Grubeguy is offline
post #17 of 17 (permalink) Old 01-16-2006, 09:49 AM Thread Starter
doc_rage's Avatar
Vehicle: 1973 280C
Thank you guys! I guess that means that I have some blockage or something in the core. The blow-by heat is great! Once the fan turns on, it blows ice cold. Blah! Hope I can just flush the system and solve the problem!
doc_rage is offline
