220SEb 1965 rebuilt engine break in time - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-13-2004, 08:51 PM Thread Starter
Date registered: Oct 2004
Vehicle: '65 220SEb coupe
Great forum and I have learned a lot here. I finally took the plunge and bought my own 220SEb, 1965 version. It has about 85,000 miles but a newly rebuilt engine.
Any special TLC I should followto it to break it in? Also, the car sat for two years before the rebuild (and before I bought it). Any things I should check out before driving regularly?
I pick up the car in a few days and will post photos then. Any suggestions on care and treatment will be most appreciated.
paloaltoW111 is offline
post #2 of 3 (permalink) Old 10-14-2004, 12:27 AM
Date registered: Jun 2004
Vehicle: 1984 w123 230ce
RE: 220SEb 1965 rebuilt engine break in time
general common sense things.. check brakes (master cylinders, rubber lines, cylinders, etc) check fluid levels, check the brakes, check the brakes!..
If the engines been recently re-built, run it in for 1500-2000 miles. I would personally keep it under 2750rpm for 750miles and then under 3250 for the rest. Make sure it has some light weight oil in it (or running in oil) and change it (and the filter) at 750miles and again at 1500miles, when you can put proper oil in it. I would remove the oil pan and clean it out at this time also.
Hope this helps
b :)
catboy is offline
post #3 of 3 (permalink) Old 10-28-2004, 10:44 AM
Merc600sec's Avatar
Date registered: Mar 2004
Vehicle: SEC 600 V12 2dr COUPE (RHD) One of the chosen few.
Send a message via MSN to Merc600sec Send a message via Yahoo to Merc600sec
And a MAGNETIC sump plug is a good idea.. gives you early warning of things ...
Torque isn't cheap
Merc600sec is offline
