67 250SE Coupe Windshield Install, need help..... - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 09-23-2004, 10:58 PM Thread Starter
grezm0nkey's Avatar
Date registered: Aug 2004
Vehicle: 67 250SE Coupe
I finally pulled out both front and rear windows. Cleaned and treated for some minor surface rust. Still waiting on seals to arrive and figured I ask for some pointers on the re-install. Glass is cleaned of old seal bits.
Im curious if the roll of window cement will raise the glass to far out.
Anyone who has done this please come foward. Any pointers and tips? Thanks in advance.
grezm0nkey is offline
post #2 of 8 (permalink) Old 09-24-2004, 07:38 AM
dbag65's Avatar
Date registered: Jul 2004
Vehicle: 1965 220 SEb 111.021
Send a message via Yahoo to dbag65
RE: 67 250SE Coupe Windshield Install, need help.....
The book reccomends a tube of cement. Eastwood has it. They use an enameled cable to pull up the seal but say a greased cord will work.
GW Bush, Duly Appointed Deserter in Chief. Somewhere in Texas a village is missing it's idiot.
dbag65 is offline
post #3 of 8 (permalink) Old 09-25-2004, 03:49 AM
wbain's Avatar
Date registered: Dec 2003
Clean the lip area on the car first. Do a net search for the type of cleaner to use.
You need to use a thin nylon cord and insert it into the new rubber. Wrap it around twice starting at the top class and finishing back at the top. Put the glass, with the rubber gasket installed on the glass including the nylon cord, on the window opening and, with two helpers pushing on the glass, draw the cord symetrically around the window. The rubber gasket flap will ride up over the metal and seal itself. Add the sealant.
wbain is offline
post #4 of 8 (permalink) Old 09-26-2004, 10:01 AM Thread Starter
grezm0nkey's Avatar
add the sealant from the backside? Do this by lifting the overlapping flap?
post #5 of 8 (permalink) Old 09-26-2004, 06:34 PM
Vehicle: 2004 E55-1970 280SEC
While you have the glass out, order a new headliner and change it out. You have to anyway. Kill two birds with one stone. And be careful, that glass is expensive to replace!
2009 C63 AMG Silver/Charcoal
1970 280SE Low Grill Coupe 2.8 Silver/Red
Past
1999 SLK230/Sport
2001 SLK32 AMG
2004 E55 AMG
Norb is offline
post #6 of 8 (permalink) Old 09-27-2004, 11:48 AM Thread Starter
grezm0nkey's Avatar
I noticed that headliner. I am not sure if it was done before, considering the leather looks newer. The headliner may have been original, Im not sure. I thought I might have been able to do it at a later date. Theres no no way to set that headliner correctly without pulling the windows, right?
post #7 of 8 (permalink) Old 09-27-2004, 05:52 PM
That is correct, you have to pull the glass to do the headliner correctly.
Past
1999 SLK230/Sport
2001 SLK32 AMG
2004 E55 AMG
Norb is offline
post #8 of 8 (permalink) Old 10-01-2004, 01:02 AM Thread Starter
grezm0nkey's Avatar
well, I got the windows in. seals are in place. wasnt easy for my first time. I learned tho.
