hydro suspension help!!! - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 09-18-2004, 09:16 PM Thread Starter
Date registered: Sep 2004
okay, i bled all the fluid out of the 4 wheel hydropneumatic suspension by means of the fittings just like on a brake system. the car is now on the ground. CAN ANYONE TELL ME EXACTLY HOW TO GET IT BACK OFF THE GROUND AND PRESSURE IN THE SYSTEM? i added fluid in the reservoir and ran the car, should i now bleed the air out by the fittings again like a brake system? PLEASE HELP, READY TO SEND THE CAR TO THE JUNK YARD! (car is a 78 450sel from germany with the 4 wheel hydo susp)
german450sel is offline
post #2 of 9 (permalink) Old 09-18-2004, 09:26 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 666 Post(s)
RE: hydro suspension help!!!
Have you tried "Checkups, hydropneumatic suspension (116.036)" from http://skinnerbox.steaky.org/Service...cksSprings.htm?
GeeS is offline
post #3 of 9 (permalink) Old 09-19-2004, 11:07 AM Thread Starter
thanks, but every single link is a dead one... any other ideas or anyway to expain it?
post #4 of 9 (permalink) Old 09-19-2004, 12:06 PM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 666 Post(s)
Oh -- sorry -- I didn't realize. I guess they're still working on getting that stuff online. The information I was try to point you toward was the Mercedes factory service manual for a 6.9, which has the very same suspension as your car.
GeeS is offline
post #5 of 9 (permalink) Old 09-19-2004, 09:25 PM Thread Starter
where did you find that link anyways, can i find one anywhere else? by the way, what is this car worth (it is a 6.9 by the way...)
post #6 of 9 (permalink) Old 09-19-2004, 10:35 PM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 666 Post(s)
I'm not real sure just what it's worth, but enough to figure out a solution to your problem unless it's trashed.
GeeS is offline
post #7 of 9 (permalink) Old 09-20-2004, 09:03 AM
5thMB1stNew's Avatar
Date registered: Nov 2002
Vehicle: '82 380SL+'02 ML320
Here is the place to start digging for help on your 6.9 suspension. As far as value goes, it was always assumed that this vehicle would make classic status, but didn't. Real MB people know that one in great shape is something special. http://www.m-100.org/6point9/. The owner of the site is an expert on it and 600s. Good luck.
1974 280 (gone)
1982 380SL (schwarzekatz)
1984 300TDT (why did I get rid of the best one?)
1992 300E (gone and forgotten)
1993 190E (daughter drives)
1994 E320 Wagon (gone and forgotten)
2002 ML320 (thank goodness for extended warranty)
5thMB1stNew is offline
post #8 of 9 (permalink) Old 10-27-2005, 01:23 PM
Date registered: Oct 2005
Send a message via Yahoo to mrjohnleslie
I need help in this area too and the link that you gave is no good
mrjohnleslie is offline
post #9 of 9 (permalink) Old 10-27-2005, 09:04 PM
Date registered: Jan 2005
You need to post your question at http://www.m-100.cc/the old M-100 .org site is dead now.
Bleeding the suspension is as easy as just starting the engine,and remeber you are dealing with close 4000 PSI !!! of Hydrualic pressure!.
start from here:Lift the car and place it onjack stands so the wheels are hanging down,then:
1/ Place the height control in "N"
2/check your oil level( do NOT use hydrualic oil!!!)
3/ start the engine and run it@2000RPM for 30 seconds to fill the control reservoir,twice as long if the entire system needs filling.
4/Lower the car and it should be at the correct height.
If this doesn't work go to the above site and ask what to do,You will get an answer very quickly.
mercmad is offline
