'79 300D Battery Problem - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 09-02-2004, 01:56 PM Thread Starter
Date registered: Sep 2004
Hi,
I have a '79 300D that keeps having a flat battery.
If I charge the battery and drive long distances the battery will restart the car fine. If I make short trips the battery goes dead and I have to boost it or re-charge it, usually I can only do 3 short trips before this happens. (Short trips as Shopping, Corner Stores, etc.)
Any ideas would be appreciated.
Raymond
rlam is offline
post #2 of 8 (permalink) Old 09-02-2004, 02:23 PM
teky's Avatar
Date registered: Jun 2004
Vehicle: chris
RE: '79 300D Battery Problem
it sound like the battery is not holding a charge "new battery"
teky is offline
post #3 of 8 (permalink) Old 09-02-2004, 03:49 PM Thread Starter
Hi,
Thanks for replying.
I guess I should have indicated that it is a new battery from the Mercedes Dealer. The one that is recommended for the car.
Raymond
rlam is offline
post #4 of 8 (permalink) Old 09-03-2004, 09:44 AM
i'm no expert but sounds like altenator problems to me. Sounds like altenator isn't delivering a strong enough charge to recharge your battery after a short drive... hope that helps.
dave_im is offline
post #5 of 8 (permalink) Old 09-03-2004, 10:10 AM
teky's Avatar
Vehicle: chris
not the alternator because it would not drive for long distance if it didn't charge the battery up, if the alternator was shot then the battery would take over the functions till it died then the engine would stop, the engine on newer cars run on the alternator not like the older generator systems where the car ran on the generator and the battery was only for starting
teky is offline
post #6 of 8 (permalink) Old 09-03-2004, 04:07 PM
MB-Owner-in-ind's Avatar
Date registered: Aug 2004
Vehicle: 83 300D
I have a '77 300D and had the same problem. Check the voltage at idle. It should be over 13 volt. If lower then I would take the car to an automotive shop where they can check both the battery and alternator. My alternator was marginal (I think one of the diodes were shot) and I had the same problem. Replaced the alt and still had the same problem but I got a bad rebuilt alt. Got another one and no problems for over a year.
MB-Owner-in-ind is offline
post #7 of 8 (permalink) Old 09-03-2004, 04:11 PM Thread Starter
I had a thought to other day. Could the glow plugs be on and draining the battery to the point that on short trips the battery hasn't the time to recover?
Is there a control switch that turns the glow plugs off after the initial start up?
Raymond
rlam is offline
post #8 of 8 (permalink) Old 09-03-2004, 04:14 PM Thread Starter
Thanks for the voltage advice, I'll check that and keep my eye on the reading if I have it rebuilt.
rlam is offline
