Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 08-21-2004, 03:04 PM   #1 (permalink)
Date registered: Aug 2004
Hard to kill the engine
We have a 79 300sd and when you go to turn engine off the motor wants to stay running, after you reve the motor up and turn the key it will cut off. Help us please.
alex149 is offline   Reply With Quote
Old 08-21-2004, 03:36 PM   #2 (permalink)
BenzWorld W211 AMG Host
Vehicle: 2004 E55-1970 280SEC
RE: Hard to kill the engine
My car had it too.
Run some valve cleaner in your gas, on old cars I've read that you should do this often. Seems if there are deposits in your valves they stay hot and ignite any left over fuel.
Also you may be running rich, or have a fuel injector stuck open.
2004 E55 Silver/Charcoal
1970 280SE/C Silver/Red
Norb is offline   Reply With Quote
Old 08-21-2004, 05:09 PM   #3 (permalink)
Date registered: Dec 2003
I'm no expert on these (or any for that matter). I believe your system shuts the fuel off when you turn off the key. It does that through a vacuum actuated control. Chances are, a vacuum line has started leaking with age. Try finding the control and placing a vacuum on it or simply replace this vacuum line with new. That may or may not fix your problem but at least it's a cheap first attempt. Of course, someone who actually knows something about these may give better advice in the meantime.
E300POS is offline   Reply With Quote
Old 08-21-2004, 08:15 PM   #4 (permalink)
jdc1244's Avatar
Date registered: Jun 2003
Vehicle: 1991 300 SE
…someone already did: E300POS is correct, you have a vacuum leak. Once fixed your engine will stop.
1991 300 SE (w126.024/M103.981) 140,000 miles
jdc1244 is offline   Reply With Quote
