Coil Polarity Changed, Added 5 Mpg - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 08-20-2004, 06:20 PM Thread Starter
Date registered: Aug 2004
I connected the coil positive terminal to ground, and connected the coil negative terminal to the ignition module.
In other words, I connected the positve terminal of the coil to the chassis (ground).
Then I connected the negative terminal of the coil to the ballast resistor.
Gas mileage went up 5 mpg to 17mpg, the exhaust tone became resonant, clear and crisp, and no more gas smell was coming from the tailpipes.
Go to Page 96, Section 10, Haynes manual for 1968-1972 230, 250 and 280 and read this statement:
If the negative terminal of the coil is connected to ground, expect up to a 60% LOSS of spark plug energy.
I know this is counter-intuitive, but the results were amazing. Anyone else been there, done that? [?]
MunichTaxi is offline
post #2 of 11 (permalink) Old 08-24-2004, 05:21 AM
Date registered: Jun 2004
Vehicle: 1984 w123 230ce
RE: Coil Polarity Changed, Added 5 Mpg
if you connect the coil backwards, the spark travels the wrong way through the spark plug, causing a weak spark, esp at higher temps.
I had this issue on a 1963 MG which had positive earth... I imagine your car is also +ve earth, hence + connection on coil needs to go to ground
catboy is offline
post #3 of 11 (permalink) Old 08-24-2004, 08:57 AM
teky's Avatar
Vehicle: chris
[:D]+/-//-/+ battery mate if it neg earth then it wont work, the coil principal is low and high tention, putting a high tention down a low tention would blow the crap out of it
teky is offline
post #4 of 11 (permalink) Old 06-01-2014, 10:47 AM
Luna Gaudi's 72 250's Avatar
Date registered: Sep 2012
Vehicle: 1972 Mercedes Benz 250
Quoted: 17 Post(s)
I know this is a very old thread, but I was wondering if anyone had anything else to add to this.
Luna Gaudi's 72 250 is offline
post #5 of 11 (permalink) Old 06-01-2014, 05:15 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 103 Post(s)
I dont believe it. The coil is a step up transformer - taking a 12 volt spike up to 20,000 (or more in some cases) spike. Hooking it up backwards would take a 12 volt spike and reduce it by a factor of equal value.
Grubeguy is offline
post #6 of 11 (permalink) Old 06-02-2014, 05:30 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
non sense . there is a reason why the coil has a marked polarity
agillot is offline
post #7 of 11 (permalink) Old 06-03-2014, 03:58 AM
ejboyd5's Avatar
Date registered: Jun 2009
Vehicle: 1955 300 SL
Quoted: 92 Post(s)
An internet search for "ignition coil polarity" quickly reveals more information on this subject than anyone wants to read. Here, for example, is one article that explains the polarity issue fairly well: Ignition coil polarity
ejboyd5 is offline
post #8 of 11 (permalink) Old 06-03-2014, 08:21 AM
NorCalSL's Avatar
Date registered: Jun 2007
Vehicle: '70 280S-'73 450SLC-'81 380SL-'84 500SEC Euro-'92 300SL24-'95 E320
Quoted: 22 Post(s)
If it says so in the Haynes, then it must be suspect.
dws
1973 Mercedes 450SLC (PineGreen/MahoganyLeather)
1981 Mercedes 380SL FORSALE (LtIvory/PalominoMBTex)
1984 Mercedes 500SEC Euro (040Black/BlackLeather)
1992 Mercedes 300SL-24 Signal Red/Black Leather
NorCalSL is offline
post #9 of 11 (permalink) Old 06-03-2014, 02:20 PM
Grubeguy's Avatar
Quoted: 103 Post(s)
Originally Posted by ejboyd5 View Post
Here is one article that explains the polarity issue fairly well: Ignition coil polarity
I'm big enough to admit when I'm wrong (and I should have known better up front) - the coil + and - posts complete the circuit for one set of windings, where the main wire completes the other, higher voltage circuit. I'm not convinced reversing the things would give better mileage and a smoother engine, but it wouldn't necessarily kill the car...
Grubeguy is offline
post #10 of 11 (permalink) Old 06-04-2014, 06:18 AM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1748 Post(s)
I wonder if this works for some folks who have bad coils in the first place. If you measure the resistance from 4-1 and 4-15 and it isn't all that different, then maybe it's ok to swap 1 and 15. All kinds of funny stuff is done to get coils to produce more spark than they can when they are crapped out. The OP probably went looking for a better solution because the OEM configuration wasn't working correctly for some reason. If your spark is good in oem configuration, then there's no need to mess with it. Plus, it's easier to diagnose the bad component because you have other oem examples to compare / swap parts with and even written specs. Once you are off the ranch, you are own your own.
There's my $0.02.
Sent from AutoGuide.com App
My signature:
Click for list of my 34 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
