Coil Polarity Changed, Added 5 Mpg - Page 2 - Mercedes-Benz Forum
post #11 of 11 (permalink) Old 06-11-2014, 10:57 AM
OldWorldShepherds's Avatar
Date registered: Jan 2012
Vehicle: 1989 560 SL - Signal Red & Palomino; 2011 C-300 - Black on Black 4MATIC
Quoted: 90 Post(s)
Interesting post, I suspect OP may have had his coil set up incorectly and simply corrected it. I know this occurs with some frequency with early positive ground vehicles from my involvemen with them, Model A Fords in particular. If you connect the coil "backwards" assuming negative ground the car will run, but with a weaker spark, correcting polarity reflects an immediate noticeable improvement - albeit not 60% as noted above.
I would guess same applies here - I know many Brit cars remained positive ground through the 60s but am not sure about this vintage MB, in any case, he certainly could have had polirity wrong on coil regardless of ground.
1989 Mercedes 560 SL
1930 Ford A Roadster
1914 Ford T Speedster
OldWorldShepherds is offline
