79 450SL Idle problem - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 07-18-2004, 05:59 PM Thread Starter
Date registered: Jun 2004
Vehicle: 1979 450 SL
I had a high idle problem - when cold my 450 would idled @ 1800-2000 rpm's, it would take about 10 minutes to drop to 700-600 rpm's.
I removed & cleaned airflow sensor plat, replaced all vacuum hoses, replaced auxilary air value. This corrected high rpm problem. Now my 450 will not idle when it warms up. Could this be a fuel problem?
Jim
jer811 is offline
post #2 of 6 (permalink) Old 07-19-2004, 01:46 AM
teky's Avatar
Vehicle: chris
RE: 79 450SL Idle problem
you probably set the airflow sensor plate too much "very sensative thing that is" http://www.benzworld.org/publications/pub.asp?id=243
teky is offline
post #3 of 6 (permalink) Old 07-22-2004, 04:26 PM Thread Starter
I reset the airflow sensor plate - still will not idle when it warms up. Jim
Help!
jer811 is offline
post #4 of 6 (permalink) Old 07-22-2004, 04:45 PM
teky's Avatar
Vehicle: chris
its all there on page 393 how to test and setup idle when hot
teky is offline
post #5 of 6 (permalink) Old 07-23-2004, 07:25 PM Thread Starter
Followed instructions on page 393 -- After 450 warms up rpm's drop and motor just quits.
HELP Jim
jer811 is offline
post #6 of 6 (permalink) Old 07-23-2004, 09:23 PM
Date registered: Apr 2004
Hi...
well.. I assume you adjusted the idle???
On the bypass valve the is the idle adjust screw.. needs to be adjusted to about 750RPM when warm...
Did you check your fuel pressure?
Did you check your control pressure?
Please post the results.
Do the plugs look fouled?
Cheers Mike
mike_1972 is offline
