Air Flow Plate "Safety Switch"??? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 07-06-2004, 02:33 PM Thread Starter
wdba123190's Avatar
Date registered: May 2003
Vehicle: 1991 300E
Anyone know the function of the above mentioned sensor/switch? It is located on the fuel distributor btw the air flow plate and the fuel distr.
(Model is a 78 280SE, but I think larger motors of the era had them too.)
Thanks!
-M-
1983 300SD
1985 190E
1991 300TE
1969 280SE Coupe (in stalled resto)
1969 Lincoln Continental (partially sold...)
1958 Jeep FC150 (you can't plow snow w/ MB sedan)
I think that's all of the current 'fleet'...
"In the land of the blind, the one eyed man is king" may be true for some time .... but you can bet that all those blind guys are conspiring to poke that last eye out.
wdba123190 is offline
post #2 of 6 (permalink) Old 07-06-2004, 03:08 PM
teky's Avatar
Date registered: Jun 2004
Vehicle: chris
RE: Air Flow Plate "Safety Switch"???
are you talking about the micro switch shown on the last drawing in the other post
teky is offline
post #3 of 6 (permalink) Old 07-06-2004, 04:23 PM Thread Starter
wdba123190's Avatar
Vehicle: 1991 300E
No. This is on top of the fuel distributor btw the plate and the octopuss, slightly to the block side but still on top of the fuel distributor housing....
maybe I'll go take a pic....
Thanks!
-M-
1983 300SD
1985 190E
1991 300TE
post #4 of 6 (permalink) Old 07-06-2004, 04:31 PM Thread Starter
wdba123190's Avatar
Vehicle: 1991 300E
This:
I know it's involved w/ the fuel pump relay as pushing down on the plate causes the FPrelay to click.
1983 300SD
1985 190E
1991 300TE
post #5 of 6 (permalink) Old 07-06-2004, 04:37 PM
teky's Avatar
Vehicle: chris
its a fuel disconnect safety switch
teky is offline
post #6 of 6 (permalink) Old 07-06-2004, 04:44 PM
teky's Avatar
Vehicle: chris
its used on the 350/80/450/500, its function is to cut fuel pump off when the pressure is up to prevent over flood conditions "i think you have just found out what your problem is m8" if its not working the pump runs on[:)]
teky is offline
