auto trans shifts to early - Page 2 - Mercedes-Benz Forum
post #11 of 16 (permalink) Old 07-06-2004, 02:59 AM
teky's Avatar
Date registered: Jun 2004
Vehicle: chris
RE: auto trans shifts to early
ill have a look for some data on it "if i can get it" that is, but it seems the system is working ok but its an old system based on electronic floor switch linked to vacuum operated solenoid ill do my best to see what i can got hold of[:)]those 3 speed boxes were not that good on the power only way to get best out of them was to use the shift lever from 1-2nd then D with foot to the floor for maximum revs in each gear which defeats the idea of the automatic really ( they are cruisers ) for street power the manual shift is the best
teky is offline
post #12 of 16 (permalink) Old 07-07-2004, 03:46 PM
JQ
JQ's Avatar
Vehicle: E430T + 300SL (W107)
On my 1973 280SE there was a stick going from the throttle at the fuel-injection that goes down to the automatic gearbox to "tell" the gearbox how much gas you are giving. By adjusting the length of that stick (very easily done) you can change the shiftpoints.
_________________
/ Joakim Quensel
2000 E430T & 1989 300SL
JQ is offline
post #13 of 16 (permalink) Old 07-07-2004, 07:01 PM Thread Starter
Date registered: Apr 2004
wohaa!!!!!!! cool
I will check first thing tomorrow... (still waiting on my manual :-( )
Thanks, I will post any updates
Mike
mike_1972 is offline
post #14 of 16 (permalink) Old 07-09-2004, 11:39 AM Thread Starter
Hi,
I found the rod that is connected to the acc mechanism (just right next to the fuel distributor towards the fire wall).. now, there are no markings on that rod.... and I really don't know which way to adjust... besides is this like trial and error? I am certain there must be some kind of specs on the Mercedes W107 1977-1979 to adjust the shift points on the tranny..... can anyone help me out [V]
Thanks, Mike
post #15 of 16 (permalink) Old 07-09-2004, 12:24 PM
teky's Avatar
Vehicle: chris
shorten the length for lazy gearing
teky is offline
post #16 of 16 (permalink) Old 07-17-2004, 12:50 PM Thread Starter
for all that want to know...
the shift points seem to be accurate...
factory spec on the 107.024 is at full throttle and position "D" 1st-2nd ~80kph ~49mph and 2nd-3rd ~140kph ~87mph ....
Cheers Mike
