NO vacuum.. my first real problem - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-22-2004, 08:21 PM Thread Starter
Date registered: Apr 2004
Hi folks,
my car is still sitting on a lift and it is getting better by the hour... all things are almost done
since my fuel pressure/vacuum gauge came in today I decided to do a little test run tonight. I had some suspicion of a faulty vacuum system, since the car cam from AZ and quite a few rubber parts are hardened and shrunk over the years alowing for air leaks....
well anyhow... I connected the vacuum gauge with a t adapter on the ingnition advance vaccum hose... startet the car and..... ZIP ZILCH ZERO NADA.. did not even move that sucker :eek:
where do you suggest do I start to test for the fault?
Thanks a LOT!!! Mike
1978 450SLC
mike_1972 is offline
post #2 of 2 (permalink) Old 06-22-2004, 10:01 PM
w108's Avatar
Vehicle: None
RE: NO vacuum.. my first real problem
Mike, I am going to use one of my books to Q&A for you...will get back to you asap
1990 560SEL - W126
-929 nautical blue metallic & 262 navy blue leather
-58,000 KM (36,200 Miles)
-Euro spec Japanese import (KAT edition)
-Complete service history since new
-5,546cc SOHC 16v V8
-10.0:1 compression
-285 hp@5200 rpm, 324 lb/ft@3750 rpm
-2.65 limited slip diff
w108 is offline
