My possible first car. - Page 2 - Mercedes-Benz Forum
post #11 of 57 (permalink) Old 06-22-2004, 08:01 PM
w108's Avatar
Date registered: Apr 2004
Vehicle: None
RE: My possible first car.
Modern physics teaches us that it takes less energy to make plastic go fast than it is to make real steele do the same thing, perhaps his allegations about the -Ford- ([xx(] argh, I actually said it) are true? [:D][:D] hehehe
Modern physics also teaches us that not only plastic takes less energey to go fast, it also takes far less energy to bend and transfers the remaining energy to the occupants of the unfortunate vehicle.
Steele may go slower, but I prefer plastic limited to the cosmetic coverings behind the door handles inside and the turn signal hehe - better to go fast in pure safety. There's a reason why banks put their money in metal safes and not plastic ones. Cars should be no different.
Tory
1990 560SEL - W126
-929 nautical blue metallic & 262 navy blue leather
-58,000 KM (36,200 Miles)
-Euro spec Japanese import (KAT edition)
-Complete service history since new
-5,546cc SOHC 16v V8
-10.0:1 compression
-285 hp@5200 rpm, 324 lb/ft@3750 rpm
-2.65 limited slip diff
w108 is offline
post #12 of 57 (permalink) Old 06-22-2004, 08:21 PM
lol.....
well it takes a LOT of power to go 160+.. AND a very good CW value....
anyhow... W108 you've got a PM
Mike
mike_1972 is offline
post #13 of 57 (permalink) Old 06-22-2004, 10:03 PM
w108's Avatar
Vehicle: None
hehehe, yes, A LOT
Message right back at you, especially loved the first part of it, it "afforded" me a few laughs, Mike [:D]
Tory
1990 560SEL - W126
-10.0:1 compression
w108 is offline
post #14 of 57 (permalink) Old 06-22-2004, 10:32 PM Thread Starter
Date registered: Jun 2004
Send a message via AIM to 1stcarfinder
To go 160 actually isnt that hard.....my brother's first SHO was automatic and it went 165....[8D]the V-6 Taurus SHO gets its extra band from the 2nd intake manifold that kicks in @4000rpm, i just love it when that happens...
1stcarfinder is offline
post #15 of 57 (permalink) Old 06-22-2004, 11:35 PM
hmmmmm unless your brother did some serious mods on the SHO it seems hard to believe it does 165 (unless we are talking about what the speedo showed)??
The gearing on a 4 spd auto 1996 makes 28.4 mph /100RPM .. 165 would cause the engine to rev 5809 RPM's ....
Based on various track tests the effective/real top speed of that vehicle is ~135 - 140mph.. which does seem about right (stock trim that is). The older version with the 5spd clocks about 140 - 145mph (again, real speed, not speedometer speed)...
On regular cars you can safely deduct 8-15mph from whatever values is displayed at higher speeds... thus is seems to be far more accurate to properly calibrate the tachometer and compute your speed based upon readings of the tachmeter..... better yet ask the cops to clock you and compare your results (lol.. of course not when you are way off the legal speed limit :-)) )
Cheers, Mike
post #16 of 57 (permalink) Old 06-23-2004, 01:29 PM Thread Starter
Actaully, It wasnt what the speedometer showed....the speedometer only went to 140.....we were @ about 5500-5600 rpm in Overdrive....We got the gear ratios from the owner's manual and calculated our speed that way.....the sad thing is that it was still pulling pretty hard @ 165....Also, go to any SHO site and read what people have to say on top speed.....it definately goes over 135....it was straight piped and had Advance Auto Air Intake.....$25...oh yeah.
post #17 of 57 (permalink) Old 06-23-2004, 01:49 PM
well that is the way to go .. calculating the top speed off the tachometer......and if ppl in the SHO forum say it does go over 135.. sure.. it all depends how things are maesured.. i.e. if the car shows 145 the effective speed is rather around 130 -135... so the stock SHO does need to sink the speedo needle every time :-) in order to go really that fast....
Anyhow.. I go back to work and try to get my tie rod appart......
Laters, Mike
post #18 of 57 (permalink) Old 06-23-2004, 03:56 PM Thread Starter
Now all i need is $200 for the down payment on the Mercedes.....I'm gonna try to put on the spare tire and borrow one of my car's batteries to get it to my house.....I dont have the money to get it towed...:/
post #19 of 57 (permalink) Old 06-23-2004, 09:19 PM
congrats dude!!!
Can't you fix the flat on the car?
If I would have a possibility I would tow it for you.. just to let you know.. the Mercedes do have a nice hook under the front bumper.. so your brother's SHO could tow it just fine .. don't exceed 45mph and 40 miles though ...
good luck !!!!!! and congrats!!!!!
Mike
post #20 of 57 (permalink) Old 06-23-2004, 10:31 PM Thread Starter
No, Unfourtunately it isnt repairable....it has a gaping hole all around the tire wall....but the car does have a full size spare...:) The car is only 1/8 of a mile from my house.....i think i can pump the back tire and maybe bring a battery to get it started. The final test is to see if it runs after the 2 years its been sittin....if it runs i will indeed buy it...that is when i get the money.:(
