1965 230SL Brake Issues - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-14-2004, 06:10 AM Thread Starter
Date registered: Jun 2004
Vehicle: 1965 230SL
Send a message via MSN to greggpat
I am in the process of returning a 1965 230SL to the road. The brakes are the only real issue as the drivetrain is excellent.
The car has not been driven in 7 years but started and run to temp on a regular basis.
This past weekend, I replaced the entire front brake assembly on both side (calipers, rotors and pads), repacked the barrings and bled the brake system at all 4 corners...now the problem.
Once the brake system was bled completely (new fluid at all bleeder screws) I noticed that the system would not hold it's pressure. Engine off, I can pump the brakes until the pedal is hard, maintain the pressure and the brake pedal will slowly go to the floor. While maintaining pressure, I get air bubbles in the rear portion of the brake fluid resevoir on the master cylinder.
I am assuming that the Master Cylinder is finished and should be replaced. Any further thoughts?
Side note, when I began working on the car, the rear portion of the brake fluid resevoir was empty. The is a stain on the ground.
Please help...the nice weather is here and the car needs to be driven.
greggpat is offline
post #2 of 3 (permalink) Old 06-14-2004, 07:48 PM
Date registered: Jul 2003
Vehicle: 1967 250SL
RE: 1965 230SL Brake Issues
I don't have an answer for you, but I belong to two internet based clubs for the 230,250 and 280SL owners with experts ready to solve any problem. www.SL113.org and www.Pagoda113.com.
I hope you will join us,
TA250SL is offline
post #3 of 3 (permalink) Old 06-14-2004, 09:32 PM
w108's Avatar
Date registered: Apr 2004
Vehicle: None
Your master cylinder rear seal is gone.
The only reason you may be able to brake at all is because it's a 2 chamber system for safety reasons.
Replace it and welcome the sun in [8D]
w108 is offline
