Go Back   Benzworld.org - Mercedes Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 06-12-2004, 10:43 AM   #1 (permalink)
Sparkalinda's Avatar
Date registered: Oct 2003
Vehicle: 1976 300D
Over heating question
My old 76 300D has been (based on the gauge reading) running quite hot lately. If I give the gauge cover a bit of a tap it jumps back down to a more “normal� running temp or 175 on the gauge.
At times the gauge can also be quite erratic and bounces all over the place.
Is this a sign of cooling system troubles or just a old tired out gauge.
Oh! and the system had a over haul two years ago including a new thermostat.
Thanks[8D]
Life is far too short to be taken seriously 8)
Sparkalinda is offline   Reply With Quote
Old 06-12-2004, 02:42 PM   #2 (permalink)
jdc1244's Avatar
Date registered: Jun 2003
Vehicle: 1991 300 SE
RE: Over heating question
Some may argue it’s a tad early but a coolant flush and refill may help. [:)]
1991 300 SE (w126.024/M103.981) 140,000 miles
jdc1244 is offline   Reply With Quote
Old 09-09-2005, 01:10 PM   #3 (permalink)
Date registered: Sep 2005
Send a message via Yahoo to new2mbenz
Sounds like the needle is just sticky if you can tap it and make it go down. Otherwise the most likely culprit is a bad ground, perhaps between the engine and body.
new2mbenz is offline   Reply With Quote
