Does anyone know anything about propane injection for the 180d? How well does it work? I understand it is very good for cleaning up dirty running diesels.
propane and nitrus have been used to overtune the diesel pickup market,a fogger system for propane is used and it will raise hp, but it is a certain blend goto a site called bullydog and read about propane injection.I own a diesel ford excursion and I am forever getting the tuner books sent to me about raise hp of your truch 100 hp and 200ftlb sof torque.alot of it is w/ propane. maybe ill try it on my 83 300tdt.
also, pull the glow plugs out that will tell you if you how the injectors are doing altho a good romp on the gas petal will also tell.my rule is replace the injectors every 300,00 miles un less there is a problem such as water in the fuel. check out preformance products web they carry a in the tank injector cleaner. If it is skipping, heres how to find out what one is cutting out .start and warm up the car , while its running, open a fuel injector and if the skipping gets worse thats not the one, do this to all the injector lines one at a time and you can find the injector thats along for a ride. changing the injector is not that diffrent than changing sparkplugs. a injector and heatshield washer shoul cost 75.00 each w/ exchange. good luck
