450SEL fuel pump question - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-07-2004, 09:47 PM Thread Starter
w108's Avatar
Date registered: Apr 2004
Vehicle: None
On these vehicles, should you be able to hear the fuel pump running when you turn the key to the "on" position? My "new" old 450 does not make any fuel pump noise, further it has a hard time starting regarless of it being cold or hot which I think may be the pump's fuse burnt out or the pump being spent. It does start eventually because of the vacuum drawing fuel up eventually...
Any thoughts?
Tory
w108 is offline
post #2 of 3 (permalink) Old 05-06-2005, 10:02 AM
Date registered: May 2005
Vehicle: 1974 Mercedes 450SL, 1975 Rolls Royce Silver Shadow
Send a message via AIM to dawood
RE: 450SEL fuel pump question
Yes, you'll hear it some on and whirr for a few seconds while it primes the engine.
dawood is offline
post #3 of 3 (permalink) Old 05-11-2005, 06:52 PM
Date registered: Apr 2005
HI. My 450SEL has not had made noise or ticking from the fuel pump in 7 the years I have had it.
However starting is instantanious with a reasonably charged battery, diffult with a smaller than standard or undercharged battery. Mine would churn away for 10 or 20 seconds before starting until I decided to charge the battery fully, then it became instantanious. I finally put in a full sized heavy duty battery, and lately I use a trickle chrager ( I only use it once a month) and no more starting delays.
Incidently, the fuel injection can only work from the high pressure pump. The vacuum will not suck fuel through the injection system as it will through a carburettor.
John Skene is offline
